RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   3Demon by Modeltech anyone? (https://www.rcuniverse.com/forum/arf-rtf-75/3755430-3demon-modeltech-anyone.html)
Ernie Misner 01-10-2006 02:46 AM
This looks like a nice light 3D plane. Does anyone have any input about it? Someone must be buying them, because they are out at the moment. I am looking for a home for my Webra 35, and this might be it. And look at the sale price on the Magic, $79.
Ernie
kinverflyer 01-10-2006 04:57 AM
RE: 3Demon by Modeltech anyone?
They have not been released here in the UK yet, my son has been flying the prototype for nearly 12 months now, powered by an old OS46fx, all up weight 4 1/2lb as you can imagine there is more than enough power. Flight characteristics, knife edge with ease, prop hanging, my son has worn the rudder out touching the ground all the time, will loop in just about it's own length, it will do all you ask of it and more.
If you look under the video section in the gallery there is a promo video I did a while back http://www.wmmfc.co.uk/
Ernie Misner 01-10-2006 02:15 PM
Thanks Kinverflyer. That is what I was hoping to hear! It looks like a real cute and nicely finished plane too. Do you think my Webra 35 would work if I tried to keep everything real light?
Ernie
kinverflyer 01-10-2006 04:34 PM
The 35 would be fine if you use mini servos and keep the weight down, it depends what you want to do with it.
Ernie Misner 01-10-2006 04:47 PM
Thanks! Well, I do want to use the Webra 35 somewhere, and I am already flying an Uproar with an OS 32 on it. Amazingly, that little 32 gives it unlimited vertical with an 11x3 APC prop. I am hoping I could do about the same with the Webra on the 3Demon. We will see! Thanks again,
Ernie
FNG 05-17-2006 05:31 PM
1 Attachment(s)
I just Finished my 3Demon. OS 32 with moose can pipe, 720 4 cell NIMH, 2 HS81MG in the wing, 2 HS80's on elevators, HS225 on rudder, and HS81 on throttle, JR610 Rx. I didn't use their linkage, mounted the engine at 90 deg for better placement of my pipe, added a tail wheel, I used pinned hinges in place of the CA hinges, the rest is stock. AUW no fuel is 3lbs 11oz.
I haven't flown it yet, but I will ASAP..
Mark
kinverflyer 05-18-2006 03:23 AM
Just finished an electric version using 650 watt motor and 5 cell lipo, unlimited vertical and flight times of 12 minutes + of full 3D flying.
http://www.zippyvideos.com/638124657...c/*kinverflyer
Ernie Misner 05-18-2006 02:36 PM
What a nice setup Mark! Is your header full length? (Mac's header?) Have you tried cutting any off?
Ernie
FNG 05-18-2006 03:19 PM
Hi Ernie, thanks for the kind words. Yes it is a Mac's, long offset. I cut enough off to go in the front of my moose can, moose can exit pipe I did not really tune the length, just winged it, when Ibuilt a second one I made it just like the first. It works good enough for me!
Ernie Misner 05-18-2006 03:53 PM
Well, at the longer, stock lengths, you will have a setup that is "always on the pipe". No peaky horsepower or jumping up on the pipe at a certain rpm. That is very good news for 3D type flying.
I have an Uproar with the OS 32 and a mac's one piece muffler. With an APC 11x3 prop it really comes alive and has unlimited vertical.
On the combat planes, they run the header way back inside of the can and get 20,000 rpms out of them!
Ernie
petri 08-29-2006 02:12 AM
Just got my 3Demon in the mail today, Build quality looks very good, covering looks excellent, no wrinkles even! Will do the "build" and radio install this weekend. Just have to wait 2 more weeks for my Jett BSE76L swinging a 14x4W....... Should be enough power :)
Ernie Misner 08-29-2006 11:42 AM
>>> Jett BSE76L swinging a 14x4W....... Should be enough power >>>
Are you serious? I was going to go with a .32. LOL
GarySS 08-29-2006 05:38 PM
That single "strand" of music wire landing gear looks weak. Will it hold up during a normal landing without compressing and getting the prop into the ground? Sits pretty with the .32 and pipe otherwise? Just wondering.
petri 08-30-2006 03:07 AM
Yes, serious about the Jett 76. It's the same size as an OS46 and a touch lighter. Swings an APC 14x4W at about 10,500, should be fairly quiet. Plus I've always wanted a Jett. I can always throttle back and the engine is more of a 3D engine, not like most of the other Jett's. About the same power as a Saito 82.
I had similar gear on a Modeltech magic and it was pretty weak, a hoop added (copper wire and solder) between the legs stiffened it up alot, but not too much. Just looking at it, I can tell this one is going to need a hoop too. The grass fields I fly from are pretty rough on smaller planes, long grass and some bumps.
FNG 08-30-2006 03:55 AM
The single strand wire is like 5/32" wire, its very stiff. Infact I broke out the mounting blocks on the softest of cross wind landings. I ended up laying some fiberglass clothe to strenghen up the blocks. I'm affraid my 3Deamon was very short lived, it had an unscheduled meeting with one the many lamppost scattered about our flying field. This occured on the second tank of fuel.
Mark
petri 09-01-2006 03:30 AM
Sorry to hear about that Mark, you just barely knew her. :( At least it's not too expensive and it's an easy build. I stand corrected on the gear, It is 5mm aluminum? rod, pretty stiff stuff and really light too! I'm going to fly it as is.
bluehawkbm 09-15-2006 07:20 PM
Do you guys think a magnum 70 4 stroke would be way to heavy for this plane?
wickkerr82 04-10-2007 09:31 AM
Hi guys, i have a Modeltech 3Demon, Where do you guys place the RX batt and receiver? PLs guys help me,
You can email me at [email protected]
thanks guys..
cheers..
vin
jgbyers1 09-06-2007 08:20 PM
1 Attachment(s)
Got a 3Demon myself. Had a Magnum .52 in it and it flew great, 3D's, unlimited vertical, etc. The rear bearing went out, blowing the crankshaft surface for the connecting rod (clunks when it turns). Will repair later. Needed a replacement in a pinch, so went with a Saito .62 4-stroke (always wanted a 4-stroke). Some may say it may be overpowered, but based on my flying experience with the .52, I don't think so. It weighs the same or less than the .52 and seems to give the same static pull. It has that wonderful 4-stroke sound and unbelievable transition speed from idle to full bore. Had to pitch the cowling for now since it was hogged out for the .52 so it's not as pretty an airplane.
Just broke in the engine, going through about 4 tanks of gas to do so (I'm very careful and followed the manual to the T ;)). Need to rebalance the plane with the new engine, but based on the power delivered by this new engine, I think I'm going to love it. Been too windy to fly but am hoping for tomorrow. I'll keep you all posted on how it turns out- maybe some cool pictures too. I attached one picture here when I had the Magnum in it. It is a good looking plane and my bear loves to fly it.
