UltraStick 120 problem !
My friend glued the wing halves of his Ultrastick without any dihedral. The wing is flat now, do you think this will ruin the flight habits of this plane and make it fly bad ?
It will be too hard to seperate the wing with all the 30minute epoxy. |
1 Attachment(s)
Hey oneplanenut
the flat wing should be find. did he install a hard wood wing joining spar?? Doug Heres my Ultarstick LW |
Doug is that US-LW a conversion job, or did they sell it at one time?
Steve |
Hey Steve
The plane started out as the stock 120 high wing stick. From Jim Feldmann plans #1307(RCM) I flipped the fuse up side down with a few other mods. The cowl, conopy, and wheel pants can be had from Stan's Fiber Tech. I'm us a Fox 2.4 w/ Slimline pitts muffler and Mejzlik 20x9 prop, pull-pull servo for rudder is mounted on bottom rear of the fuse. the elevator servo is also mounted in the rear. The plane flys great and the crow is a blast!! Doug |
Scratching my head...?
It really puzzles me why an ARF manufacturer/importer doesn't offer us a model such as the Ultra Stick in a low wing version. I think it would sell very well.
| All times are GMT -8. The time now is 06:22 PM. |
