RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Phoenix Decathlon (https://www.rcuniverse.com/forum/arf-rtf-75/3897734-phoenix-decathlon.html)
firewood 02-11-2006 03:18 PM
Phoenix Decathlon
Please help. Has anyone put an OS 46 LA in one of these planes? Also, has anyone figured out the exact CG and control throws? I'm also considering a Magnum 70, but it doesn't fit in the stock engine mount. If anybody has put one of these engines in, could you tell me how you did it?
Bob
Primodus 02-11-2006 10:02 PM
RE: Phoenix Decathlon
I have a 46AX on mine and it is a great plane to fly. The Magnum 70 would be a great choice as well, but the 46LA would be nominal at best for this plane, I think. The Magnum would also have the better sound and more power in the vertical. Get a bigger mount and try the 70 on it and let us know how it goes :)
firewood 02-12-2006 08:39 PM
thanks for your advice but could you tell me where your planes cg is at and what your control throws are thanks bob
Primodus 02-12-2006 09:00 PM
CG=100mm
Ailerons = max throw
Rudder = max throw without hitting the elevator
Elevator = not exactly sure what I have here, looks like 1"- 1-1/4"
ctsieber 02-12-2006 09:09 PM
ORIGINAL: firewood
Bob
with a 46 LA this plane is going to be really doggy.
I have one ordered, I'm putting a magnum 70 4-stroke on it.
firewood 02-12-2006 11:15 PM
thanks guys :D
pjw_75 02-13-2006 02:36 PM
Why not try a .60 fx 2 stroke on it
mikeboyd 02-19-2006 12:58 PM
1 Attachment(s)
Just finished one of these with a .91 Magnum four stroke. Pictures of the modifications to help on your .70 four stroke installation.
1. Mounted elevator and rudder servos in the tail with the battery just forward of them.
2. Blocked off holes in cowl adjacent to the spinner, opened the lower hole and installed stall strip to enhance airflow over inverted engine head area.
IronCross 02-19-2006 09:09 PM
Nice Mike... When you going to fly it ?..:D
firewood 02-19-2006 09:18 PM
1 Attachment(s)
thanks alot mike for the great info all most decide not to do it till now you got sny pics with the cowl off they would be so help full thanks bob
