what is the difference here????
I am looking for a 60 size arf, I found these, without a price though, could some one tell me what the HE!! the difference is in these two planes....do i want built up wings or foam core...I will put a saito 100 on it.
forgot this part of the thread
http://www.hobbico.com/airplanes/hcaa2600.html
http://www.hobbico.com/airplanes/hcaa2080.html which one is better for a saito 100 |
Whaaa?
The blue one is a 300.
The white one is a 300S. The S has a lower and shorter wing. They fly very similar. Just go for the one you like best. |
also, the blue and red one is discontinued, you'll be hard pressed to find it anymore, i know tower no longer has any, but i have flown both and will tell you both fly very good. please do not be afraid of foam wings, as most airplanes when they get larger have foam core wings i.e. lanier edge,extra,cap ,the foam wings are actually more strong in a wing type setting, i have never had a problem with a foam wing plane.
I've heard good things about those planes, but have no personal experience.
Mike |
The foam wing will be a little heavy compaired to the built up, but the foamy will take a hit better. Whats the difference between a dog and a wife?.....The dog is happier to see you the latter you get home.
thanks for the replies
I am not concerned with weight.......30 oz wingloading ...could care less. In my opinion 25-30 oz wingloading land better anyways...I hate floaters.......
the foamy will NOT take a hit harder than the wood version. By foamy I am talking about the ASAP blue version. Stay away from it! I had the 40 size. I can say that it was very light and flew beautifully. However, in a takeoff incident I managed to rip the foam covering in about a 5 inch gash. This stuff is not easily repaired! The plane is basically a ply stick skeleton covered with a thin foam/plastic hybrid covering, typical of the early ARF's. You would be much better off getting the all wood version. It will be a little heavier than the foam version but worth it in durability and repairability.
| All times are GMT -8. The time now is 06:56 AM. |
