Problem w/GP Christen Eagle cowl
Hi All,
I just bought a GP Christen Eagle from Tower. Everything looks great with the exception of a very small crack in the cowl. The crack is in the corner of one of the air duct openings. I never had a plane with a fiberglass cowl before. Should I be concerned? Do I complain to GP or should I just try to fix it it myself. IF fixing it myself is the best option how do i do it? Thanks in advance for help you can provide. Chuck |
RE: Problem w/GP Christen Eagle cowl
I'd contact GP and tell them about it, then if they send you a new one COOL. If not I'd consider fixing it my self. By the way if GP says they will send a new one, make sure you don't have to send the old one back and go ahead and fix it.
I fix my own stuff but I'm not going to try to tell ya how to fix yours. I do know that the first thing I would do if fixing it would be to drill a small stop gap hole at the end of the run then work from there. Good Luck ! ENJOY !!! RED |
