RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Diablotin Warning (https://www.rcuniverse.com/forum/arf-rtf-75/450088-diablotin-warning.html)
JBrannon 12-31-2002 03:24 PM
Diablotin Warning
1 Attachment(s)
I have the JR Models Diablotin JR63. I got it from Esprit models for $279.00.
I really loved the plane untill the wing separated from the fuslage when performing outside loops.
I have contacted Esprit Models and the man that answered the phone told me to email him the photos and he will contact the manufacturer about replacing the airplane.
I will update post with results of his efforts.
I will attach several photos that show the cause of the failure.
The first is a scan of the plans provided with the plane to show how the wing is attached.
Joe Brannon
JBrannon 12-31-2002 03:29 PM
Diablotin Warning
1 Attachment(s)
The next photo shows the fuslage with wing attachments as I found it after crash. You can see parts of the wing sheeting, the wing reinforcement blocks and the wingbolts.
The wing separated because the wing reinforcment blocks were not glued to anything and the only thing holding the wing on was the wing sheeting, which failed.
JBrannon 12-31-2002 03:32 PM
Diablotin Warning
1 Attachment(s)
Here is a close up view of the wing reinforcement block. You can see there is no evidence of any glue. Also if there had been glue you would have seen some tearing of the wood, but you dont because no glue was applied to this structure component at all.
JBrannon 12-31-2002 03:36 PM
Diablotin Warning
1 Attachment(s)
The next photo shows the wing at the point of failure. You can see again there is no eveidence of any glue being applied to wing or wingblocks, the sheeting was the only thing holding the wing on the airplane.
JBrannon 12-31-2002 03:42 PM
Diablotin Warning
I have many more photos available but I think these show the lack of glue and the that I built the plane according to the plans.
If I was building another, and I hope Esprit will replace the plane so I can, I would remove the sheeting on the bottom of the wing where the wingbolts go thru, sqiurt some thin CA in, and replace with lite ply.
If I was flying one that was already built, I would remove the sheeting from the top of the wing and get some glue in there asap.
Of course the fuselage suffered major damage as it lawndarted in. The ground was soft so I dont think there is any damage to the engine, but I will have to check the crank for straightness.
Joe Brannon
Flyin Woodbutcher 01-01-2003 02:46 PM
Diablotin Warning
Hey Joe Dont back off a bit ,they should replace your plane. Its real luck that no other expensive parts were damaged..
Good Luck Kent Huntsinger
JBrannon 01-12-2003 09:09 PM
Diablotin Warning
Still no response from Esprit Nodels. Have emailed them twice and called once.
Joe Brannon
OUTCAST 01-12-2003 10:50 PM
Diablotin Warning
From what I see in the photos, this one is a no brainer. I can't think of any reason Esprite should have to contact the manufacture to ask permission to replace the plane. THEY are after all, the ones who sold you a defective airframe......right?
JBrannon 01-13-2003 02:17 PM
Diablotin Warning
Esprit Models says they are still waiting for a response from the manufacturer of the airplane.
Joe
JBrannon 01-21-2003 01:06 PM
Diablotin Warning
Still no response from Esprit Models. I have emailed him repeatedly and all he says is he is waiting for the manufacturer to respond and he will get back to me. Which he hasn't He is probably hoping I will just go away. I wont.
Joe Brannon
JBrannon 01-29-2003 03:52 PM
Diablotin Warning
I talked to Esprit Models today and they say they are replacing the airplane. They say they will ship a new on to me today.
I will update when I receive the new plane.
Joe
