RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Engine Mounting Giant Big Stick (https://www.rcuniverse.com/forum/arf-rtf-75/4520606-engine-mounting-giant-big-stick.html)
SIREX 07-19-2006 02:38 PM
I have a giant big stick from GP. It is set up to mount a Fugi but said you can use any gas engine. My question is has anyone mounted another gas engine on this plane? Also how do I know where to put it? I have the template from http://www.bcmaengines.com/ I have the SPE 40.
Is there an offset or anything or do I mount it dead center?
Any help would be greatly appreciated.
sw1241 07-19-2006 04:02 PM
RE: Engine Mounting Giant Big Stick
I put a 25 ccc Homie on mine w the nose gear,I used the Fuji mount for a template and marked the crankshaft center , then laid out the homeie plate aligning the center, moved one standoff to square the stands up and presto, changeo it fits and is in the air.
Harc 07-21-2006 02:57 PM
SW - Just ordered the biggie stick. Plan on using an ST 2300 which is sitting idle. How does this hummer fly? Would appreciate any info.
Harc
