Ryan STA
I am building a Rayn STA and need some help in selecting servos. The amnual recommends only 45 0z-in torque servos--I installed the higher torque futaba S3010 servo @ 72 oz-in. My friend suggests I should also upgrade to the metal gear design servo. I am not a high hour flyer and not a lot of fancy stunts, so wonder if the S3010 are actually adequate.
Paul Cobb |
RE: Ryan STA
Hi Paul, The 3010 fut. servo will be fine for what you want to do. If you were to go to a large gas engine then you might want to go to metal gears. Wayne M.
| All times are GMT -8. The time now is 05:45 AM. |
