RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   GP P6E Hawk Help (https://www.rcuniverse.com/forum/arf-rtf-75/4791723-gp-p6e-hawk-help.html)
jcw111 09-25-2006 04:22 PM
GP P6E Hawk Help
Need help with the wing incidence on the Hawk
I am setting up the wings on the Hawk and the top wing is at 3 degrees negative which seemed excessive I checked with GP about the Top and bottom wing incidence and was told the Top wing should be 1/2 degree negative and the bottom wing to be 2 degree negative. My top wing assembled shows about 3 degrees negative and will have to be shimed to get the 1/2 degree negative The bottom wing is OK All the struts are installed correctly. Have any of you that have built this plane had the same problem. Would appreciate any comments and advice. I am using the Robart incidence meter for set up
Jim Whitney
fly TN 12-02-2006 09:19 AM
RE: GP P6E Hawk Help
hello , i am looking for a RC Curtiss P6E kit ( not ARF ) with a 3-4 ft. wingspan. they run about 200-400 $ anyone know where i could find one?
thanks
XTRA230 12-03-2006 07:45 AM
Try The extensive build thread Starts here http://www.rcuniverse.com/forum/m_34..._1/key_/tm.htm You May have to do a bit of reading Up To 1003 Posts It Is here RC Warbirds and Warplanes Hope this helps
Rob ;)
