RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Phoenix extra 330s fire wall? (https://www.rcuniverse.com/forum/arf-rtf-75/5116189-phoenix-extra-330s-fire-wall.html)
M64 12-14-2006 03:47 PM
Does anyone know about the extra 330s fire wall? if I put an O.S 91FX on it would i need to strengthen the fire wall?
If anyone can help it would be great.
M64
tande 12-14-2006 07:14 PM
RE: Phoenix extra 330s fire wall?
Doubt it---I've got a YS110 & "Hyde/Mt" on mine---Been flying the *rap out of it---No problems---Before you mount the .91, point the nose down & drip saturate all the firewall joints from the inside with thin "CA"---Then go fly the *rap out of it!!---(Your mileage may vary)---
M64 12-15-2006 04:47 AM
Thanks very much tande!
M64
M64 12-15-2006 08:52 AM
Are there any other changes that have to be made in or on the plane?
M64
tande 12-15-2006 11:24 AM
Well----I've not made any SERIOUS changes, although I am using larger dia. wheels (3")---Also 1/4" length of large fuel tubing under each canopy screw hd. (allowing it to compress & act as a lock), they can & WILL vibrate loose!---I just happen to like "Sullivan" tailwheel assy. & so thats what it has---Thats about it, all the other hardware (except wheels) seems to be good, IMHO, maybe the "Best bargain in the store" for the money----OH! & the control surfaces are VERY sensitive!!---Especially the elev.---It's HUGE for the size of the airplane!!---Now about SERIOUS changes---I am considering cutting the elev. counter/balances off & attaching them permanently to the stab & possibly shorting & doing the same to the ailerons (4" or 5")---(I'm sure you can tell, I'm NOT a 3D flier)---Hope this helps---
M64 12-15-2006 03:16 PM
Thanks again. can you post a picture of the screws an fuel tubing assy on your canapy it would be a great help.
Thanks very much.
M64
tande 12-15-2006 07:04 PM
1 Attachment(s)
Not "Rocket Science"---But it doe's work---Tighten hatch bolt only enough to compress tubing approx. 50%---
M64 12-16-2006 02:56 AM
That is very clever!:D I'll try it. thanks again.
Did you put a bigger tank in your extra?
M64
M64 12-16-2006 03:22 AM
Can you post more pics of your plane? it looks great?
What size tank are you using and how long is your flight time with it?
Thanks again
M64
davo580 12-16-2006 04:33 AM
as with most arf / rtf make sure you go over it with zap or flash
M64 12-16-2006 05:14 AM
what do you mean by 'zap or flash?'
M64
tande 12-16-2006 08:31 AM
ORIGINAL: M64
M64
No, I used the stock tank---
M64 12-17-2006 04:09 AM
can you post some pics of your setup inside your extra.
what is your flight tome with the stock tank?
M64
tande 12-17-2006 02:02 PM
1 Attachment(s)
ORIGINAL: M64
M64
Stock tank + YS110 = 12/15 min. I guess---More than enough for me!!---
M64 12-17-2006 03:15 PM
great pics. why 2 batteries?
M64
tande 12-17-2006 07:13 PM
ORIGINAL: M64
M64
Just do a search on "Redundant batteries"---Easier than me trying to explain---& I needed tail weight anyway, might as well make it usefull!---
M64 12-18-2006 12:49 PM
is the YS 110 a 4 stroke. can you post any pics on the engine, cowl, etc
M64
tande 12-18-2006 07:28 PM
1 Attachment(s)
ORIGINAL: M64
M64
Yes, the YS110 is a "Supercharged" four stroke---
M64 12-19-2006 08:21 AM
thanks for the pic!!!!!:D. Do you have any pics of the plane in flight?
M64
tande 12-19-2006 07:47 PM
ORIGINAL: M64
M64
Nope Sure don't---
M64 12-27-2006 12:52 PM
Do you have pics of the underside of your plane including the wings?
N64
