Y/A Edge tail setup
I am now getting ready to put in the push rods and the Pull - Pull system. First I have no slots or holes cut in the tail (like the instructions say). But more importantly I can easily see where the elevators and the rudder will bind up with each other.
Can anyone who might have this done send me some pictures of the tail area so I can get a better idea of what is needed? This is for the Edge 540T 1.20. Thanks in advance for the help, Eric [email protected] |
Y/A Edge tail setup
Welcome to the world of Yellow Aircraft. I have a 60 size one that I've been trying to put together for about 4 weeks now. I've got the wing together and the motor mount in place. The original won't fit, either will the fuel tank. This is an ARTB "Almost Ready to build". I spent an hour or so yesterday with the same tail control issues. I'm not going to use the control horns that came with the kit for the elevators (to Big) and I'm running the pull pull about 5/8" below the elev. push rods I think it will work.
Y/A Edge tail setup
I'm building a 120 size Yellow Aircraft Edge now, but I haven't got to the tail feathers yet.
I will take a look at mine tonight and see if I can see what you are talking about. Jim |
Y/A Edge tail setup
I have the pull-pull setup. Now working on the elevators. Y/A did not include enough hardware. I am short 2 of the horn brackets to connect the Elevators. I will take some pics and post them tonight.
Eric |
Y/A Edge tail setup
I don't have my tail feathers mounted yet, but I held them in place and can see that then control horns will be close. It looks like it will work out O.K. though. I won't really know for sure until I get the plane assembled more.
Sorry I couldn't help more, but I am behind you on the assembly of this plane. Jim |
Y/A Edge tail setup
1 Attachment(s)
Tail 1
Y/A Edge tail setup
1 Attachment(s)
Tail 2
Y/A Edge tail setup
1 Attachment(s)
Servo Mounting
Y/A Edge tail setup
1 Attachment(s)
Full Plane 1
Y/A Edge tail setup
1 Attachment(s)
Full Plane 2
Y/A Edge tail setup
Nice job. What is the wingspan on your plane and what kind of engine are you using??
Y/A Edge tail setup
The span is 72" and I am using the Saito 1.80 for power.
Can't wait to fly it. Should be unlimited vertical and a blast to 3D (or at least try to 3D). Eric |
Y/A Edge tail setup
I use a Saito 180 in a 72 inch Hanger 9 Cap. You will love that engine. Try Heli fuel. Costs more but you will love the performance.
| All times are GMT -8. The time now is 10:24 PM. |
