RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   fast plane (https://www.rcuniverse.com/forum/arf-rtf-75/5675984-fast-plane.html)
monster man14 04-06-2007 06:28 PM
fast plane
can you guys tell me what plane out there is like screaming fast with ailerons, and has any engine size between .50-.91 2-stroke engine please
aussiesteve 04-06-2007 06:35 PM
RE: fast plane
Viper 500 with Jett 50 engine.:D
oldhippy1 04-06-2007 07:15 PM
RE: fast plane
How about this classic with a Super Tigre 90 2 stoke http://www.greatplanes.com/airplanes/gpma1320.html
monster man14 04-06-2007 08:17 PM
RE: fast plane
can a 3d plane go as fast as a pylon racing plane? if not, then why not?
aussiesteve 04-06-2007 09:28 PM
RE: fast plane
They can - but not for very long:D
2 main reasons
3d planes have large control surfaces that have a tendency to flutter at high speeds. this usually results in mid air destruction of the airframe and is near impossible to stop.
The large control surfaces are usually way too effective so at high speeds, the slightest movement of the surface results in a change of attitude of the plane.
Also - the airfoil sections etc are not designed for speed and they tend to have a lot of drag. If you were to try and power one to go fast - it would take a HUGE motor to get a good speed.
monster man14 04-06-2007 09:30 PM
RE: fast plane
oh, so if the control surfaces were smaller on the 3d, it would fly almost as fast the pylon racing, correct?
aussiesteve 04-06-2007 10:05 PM
RE: fast plane
Probably not - 3d planes tend to have a high frontal area whereas the speed planes don't.
Get a 3d'er and look at it straight on from the front, then look at a speed model and look at it straight on from the front - you will see a lot less plane on the speed models - thin wing chord, more stramlined fuselage etc.
dieFluggeister 04-06-2007 10:14 PM
RE: fast plane
Two completely different machines built for two completely different purposes. Tractors don't run NASCAR.
tmaucher 04-06-2007 10:22 PM
RE: fast plane
Ive seen an advertisment for weston uk. This is a british co. that now is distributed in the us. Ive seen a video and their plane is stupid fast. 50 size plane and engine combo. wicked fast baby
tIANci 04-06-2007 11:45 PM
RE: fast plane
Magnum R from Weston UK ...
SJN 04-07-2007 03:58 AM
RE: fast plane
1 Attachment(s)
Yea, the magnum with West .50 V1 engien is nice [sm=thumbs_up.gif]
http://www.youtube.com/watch?v=C9PxFc2XJ3E
orenda635 04-07-2007 09:27 AM
RE: fast plane
ORIGINAL: aussiesteve
I second that. Those Q500s are built for speed. Actually, that might be a fun plane for the OS Wankel.
I bought a similar one already built, but it has a bizarre ring style engine mounting system. I couldn't figure out how to install the engine.
Sturtz 04-07-2007 10:34 AM
RE: fast plane
Voodoo.
aussiesteve 04-08-2007 05:07 PM
RE: fast plane
Hi Orenda365
They mount through the backplate bolts for the motor.
It saves a lot of weight - other than some slightly longer bolts there are no additional bits like an engine mount to worry about.
mr sopwith 04-09-2007 09:32 PM
RE: fast plane
1 Attachment(s)
Little Toni from Great Planes is looks nice, I heard one clocked 120 mph with Saito 1.00 four stroke engine, but more faster with 2 stroke engine.
jbflier 04-10-2007 04:12 AM
RE: fast plane
I used to see an ad for a plane called the Diamond Dust that claimed speeds of 175-200 mph.....I think Morris may carry it now;)
tIANci 04-10-2007 04:58 AM
RE: fast plane
The Lil Tony is not that fast, seen it fly on a YS110 ... Diamond Dust is very fast with a really hot motor but its better to look for the pylon planes, the 21/25 sized ones. Maybe the MagnumR.
