Patty extra
Hi I am putting together a Great Planes Patty Wagstaff and have come to the part about attaching the tail feathers.It doesn't look like there is enough wood for a strong joint.Also how do you slide
the stab in the fuse without getting epoxy on the stab. [email protected] |
Patty extra
You apply epoxy to the stab saddle and the stab, than slide in place. Use alcohol to clean up, just follow the instructions it works perfect. I did what the instructions said and it worked great no problem.
Patty extra
You may want to check this thread on the Waggy. Just about everything you may encounter is in there...somewhere.
http://www.rcuniverse.com/showthread...hreadid=282608] |
Patty extra
I use epoxy until it was set then used liquid nails to fillet the entire joint!
Patty extra
what is liquid nails?
Patty extra
I used gorilla glue and it set up like stone!!! good stuff
| All times are GMT -8. The time now is 10:22 AM. |
