RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   replace tailwheel on Pulse XT (https://www.rcuniverse.com/forum/arf-rtf-75/6131932-replace-tailwheel-pulse-xt.html)
ro347 07-19-2007 04:05 PM
Has anyone replaced the tailwheel assembly on the Hanger 9 Pulse XT? If so what did you use?
reincarnate 07-19-2007 04:25 PM
RE: replace tailwheel on Pulse XT
Sullivan. Gives it better ground stance and handling too.
what_stanger 07-19-2007 05:07 PM
sullivan here as well, however it was a fourstar.
gmeyer-RCU 07-19-2007 05:15 PM
Sullivan I use it on all my taildraggers
jlank 07-19-2007 08:44 PM
My vote goes to the Sullivan also. It's the only 1 I use!!
ro347 07-19-2007 10:56 PM
Could anyone provide a pic of your installation? I am trying to figure out if I have to cut the bracket to fit considering the tail bolts on this model. Did you epoxy/glue down?
Thanks so much!
hetr 07-20-2007 09:20 AM
1 Attachment(s)
sullivan is also my vote
suprisingly it just bolted in place with spacing of rear bolt and tail of fuse= l just had to file down the sides of the mount a bit for the nut area - as per pic - then just used a small screw at the very back for stability - the mount is suited perfectly to tail shape - no glue - the main bolt/nut holds great
l have just left the tailwheel to freely caster - no real difference on ground handling - but who wants to be on the ground anyways?
(l love this plane - but l also replaced the main wheel axles with proper du-bro axles - the supplied socket head bolts bent on some of the earliest flights)
PE2fan 07-20-2007 09:35 AM
Mine is almost exactly the same as hetr's. I also had to replace the axles after the second flight.
ro347 07-20-2007 09:39 AM
HETR.....THANKS SOOOO MUHC. THATS EXACTLY WAHT I NEEDED TO SEE AND WHAT I HAD EXPECTED I WAS GOING TO NEED TO DO. THANKS AGAIN FOR GOING OUT OF YOUR WAY.
opjose 07-20-2007 10:43 AM
Tower Hobbies Ultimate tailwheel assembly.
$1.89/ea, I buy them by the dozen... good for .40's up through 1.20's.
ro347 07-20-2007 05:56 PM
would 1 or 2 servo screws be enough to hold the bracket on the rear end? or should I look for larger screws?
what_stanger 07-20-2007 06:31 PM
if you're using blind nuts i would think 2 would be fine, on opposite ends of course.
I couldn't put the blind nuts in, so i used 4 screws into (ca hardened) wood. Its been ok so far.
EDIT: spelling.
ro347 07-21-2007 12:43 AM
ORIGINAL: what_stanger
EDIT: spelling.
Sounds good to me!
Fastsky 07-22-2007 07:28 AM
The 2 bolts hold very well indeed. On some planes I needed to mount the tail wheel assembly a bit below the plane to clear the rudder so I make a wood block out of aircraft ply the same shape as the nylon piece. I install the blind nuts and then epoxy the wood piece to the bottom of the fuselage. When the epoxy dries I use a small drill smaller than the blind nuts and drill through the blind nuts into the fuselage so that the bolts can go through without breaking the balsa. Its a bit of work but its worth it. Tip, the Sullivan comes with 2 sizes of springs. Use the larger one for better tail wheel response. ;)
ro347 07-22-2007 09:42 AM
Thanks guys. I went with the sullivan and the larger spring. Used two screws along with the tail feather bolt into ca hardened wood. PERFECT. Thanks again!
