RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Bob cat (https://www.rcuniverse.com/forum/arf-rtf-75/6203038-bob-cat.html)
dave48 08-06-2007 12:01 PM
Bob cat
I hope someone here has built one , my Q is on mounting the eng. Now do you need to off set the eng. ? and also they said the landing gear was weak , what would be a good replacement set ?
soarrich 08-06-2007 02:00 PM
RE: Bob cat
I'm going to use a Dubro plastic LG mounted right under the engine.
opjose 08-06-2007 02:09 PM
RE: Bob cat
Already answered.
Up/Down thrust is built in.
Since this is a pusher "P-Factor" is not as dramatic, so keep the engine straight.
You can re-inforce the gear by soldering in a metal wire cross brace, much like you would a strut for the tail.
Simple and cheap. There is a picture of this on one of the Bobcat threads.
The included gear is only OK, but it will not hold up to a hard landing. Re-inforcment wouldn't hurt.
That said, I would MUCH rather have the gear give and bend out, then have the fuselage or wing damaged on a plane because of a hard landing.
