World Models Ultimate 40S
I'm lookin' at a World Models Ultimate 40 size. (Ultimate 40S)
Of course, magazine review is favorable, from the web site model looks good. Any feedback or experience?? Allen |
RE: World Models Ultimate 40S
a clubmate of mine has one, it flys very well but there were niggling build problems like pre-drilled holes not lining up etc.
nothing serious, just time consuming and annoying. |
Thanks!!! That's really no problem.. I'm an "arfer", so those little things are kinda' expected....
Allen |
1 Attachment(s)
It's an amazing little thing.
There was a long thread about it's aileron rigging. It's worth your doing a search on these forums for it. The rigging provided in the ARF winds up deflecting the ailerons at different rates, so they don't move equally. There is an easy fix. It's all in the earlier thread. |
There's a couple of good threads on this model.
Make sure you use plenty of extra CA everywhere you can reach (and as many places as you can't reach). We had one that was pretty weak in all the joints but I have been assured that it must have been a "Friday plane". When it was flying, it flew well it just didn't have much strength in any of its joints. |
1 Attachment(s)
I had one for a while. It's a pretty nice plane for the such a low price. With a .46-AX it was plenty fast. The only real weak spot I found on mine was the wing bolt plate. It would come loose even with only slight contact between the wingtip and the ground. Of course the best way to avoid that is to not put the wing on the runway in the first place. As with all of the lower cost ARF's, look it over good and beef it up where necessary.
Wonderful!!!
Thanks guys for all the info.. I'll try the search... Allen |
Can't wait to finish mine!
I am using Hitec super thin servos for ailerons. They are mounted inside the wing on servos covers. The only thing exposed will be the control rod. |
So much material!!
Can someone give me a link to "Changing the ailerons"?? I have not been able to find it... Thanks!!! Allen |
I've got one of these little buggers too. Some of the work is done but I can't find the aileron info either. Was going to go ahead and go by the "not too good directions". lol I only got it to use my OS 46 and Futaba 3004s on. Actually all the stuff that was in my Twist will go in it. If you find the info, link it here please.
i got one of these planes about 3 weeks ago , took me about 10 hrs or so to get it ready to fly, like many others i did not like the idea of a micro servo running four ailerons so i used a futaba s3004, took it to the field for its maiden, and ran into a problem the servo did not seem to want to give me much throw in my ailerons, after some fooling around i realized i did not glue the rods that connect the lower ailerons together, so i did this with some thin CA, that helped a bit, but was still pretty much having the same problem on further investigation i figured out the ailerons were real stiff, i took it home and worked them up and down like crazy, but still no joy so to remedy my problem i cut a bigger hole in the wing and turned the servo so that it was length ways across the cord then added a second servo right beside it i know this added a lil bit of weight but aileron problem solved.
as far as the overall build it was pretty straight forward the jigs to align the wings was great, unlike the above post all my predrilled holes lined up nicely, and i loved the clear cowling with that i probably made my best looking cowling ever as far as cutting it out around the engine, i opted for mounting the engine on its side just because i do not like sticking my hands underneath a running plane especially one that sits that low. once it was complete i checked the CG and it was right on i mounted the reciever next to the fuel tank, and the battery near the firewall on top of the tank in the opening there my setup is servos: 5 futaba s3004 (2 aileron 1x rudder 1x elevator, 1 x throttle RX: Futaba Par 2 4ch TX: Futaba 7cap engine: O.S. 55 AX Battery: Futaba 1500mah the plane flies great, has enormous amounts of power with that .55, its pretty fast, and pretty touchy on the controls even with the suggested throws, T/O is a lil touchy with all that power it wants to roll from the torque, flight is nice once you get comfortable with the controls, it doesn't like to land.....lol our field is surrounded by trees by the time i get low enough you almost half to force it down, cuz it gains alot of speed on the decent. |
like many others i did not like the idea of a micro servo running four ailerons so i used a futaba s3004, I just pulled out the assembly booklet. I built mine back in early 2006, and those plans didn't suggest any size servo. And the pictures weren't good enough to read the numbers on the Futabas they used. At least a Hitec 225 Mighty Mini works great. It's not only lighter than the s3004 by 30% (.9oz versus 1.3oz) but it's stronger. The HiTec puts out 56oz-in while the Futaba does 44oz-in. |
ORIGINAL: a68fan So much material!! Can someone give me a link to "Changing the ailerons"?? I have not been able to find it... Thanks!!! Allen I've done the above on one 40S, and left the default setup on, on another. There really wasn't a lot of difference in the handling of the plane. I'd imagine that it would be much more effective on a larger plane... I did as per DaRock's suggestion on my 1.20 sized Ultimate. The Hitec Mini is sufficient to drive all four aileron's w/o problems. This plane doesn't need a huge amount of control surface movement. "Binding" is the big bugaboo. You MUST make sure that your ailerons move easily to their extremes with very little force. Make sure that you leave sufficient gap in the hinges to permit this. You don't want too much, and you don't want too little. The width of one of the control rods should suffice. |
| All times are GMT -8. The time now is 10:10 AM. |
