RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   SERVO HELP!!!!!! (https://www.rcuniverse.com/forum/arf-rtf-75/8194636-servo-help.html)
davejerr 11-29-2008 01:11 PM
SERVO HELP!!!!!!
I have a giles 202 and an extra 330l (basically the same planes) both being powered by a ttpro .46...What servos should i use? When i do research, everyone always uses a higher torque servo for the throttle. Is that true? and why? it needs 5 servos by the way..
Birman 11-29-2008 01:22 PM
RE: SERVO HELP!!!!!!
I don't know why someone would tell you to use a high torque servo for the throttle. A standard works fine. For the control surfaces a good all around digital servo is the JR DS821.
You can use it with Futaba equipment. Here's the specs: Torque:72 oz/in @ 4.8v, 88 oz/in @6v. They can be found on fleabay for bargin prices, or go here if you want new ones:
http://www.horizonhobby.com/Products...ProdID=JRPS821
Be advised though, digital servos draw more current from your flight pack.
Birman
w8ye 11-29-2008 01:32 PM
If you are not trying to fly 3D style just regular servos will serve you well.
DadsToysBG 11-29-2008 01:38 PM
To answer your question about 5 servos. The wing is using 2 servos. Then you have one on the elevator and rudder and throttle. These planes are .46 size any sport servo will work like the JR sport BB .$12.99 ea. Dennis
Jetdesign 11-29-2008 02:04 PM
Those are both very aerobatic and 3D capable planes. I would use the DS821 servos mentioned above. They are high torque and digital, so they have better holding power and are more precise. There are ads for much less than retail in the classified section. I have a Venus 40 powered by a OS 46, and the digitals are SO much nicer on that plane.
MetallicaJunkie 11-30-2008 04:32 AM
ORIGINAL: w8ye
if so hitec 475hb's will do you all around...
BarracudaHockey 11-30-2008 10:37 AM
821's aren't appropriate for a lot of helicopters and larger planes, but they ship with DX7's and 9303's so there's loads of people selling them in the classified forums for cheap, 60 bucks for a 4 pack is about average.
blvdbuzzard 11-30-2008 02:03 PM
I have the Giles 202 50 sized from Nitroplanes. I am using the $10.00 servos from Hobby people. Th GS-601 [link=http://www.hobbypeople.net/gallery/440601.asp]spec's[/link] They have been really good so far.
Dru.
Jetdesign 11-30-2008 02:11 PM
ORIGINAL: BarracudaHockey
Very true - not for big planes, but great for small (.40 to .90) aerobats.
jship 11-30-2008 02:45 PM
Message deleted.
