Cermark F16 what engine?
I've read most of the thread in the fast prop forrum,but by the time I'd read half way through my nasal hair needed triming. Yes a Limey has brought one of these and this limey would of thought an OS 91 fx would of been the perfect choice. However I don't see any mention of this engine being installed in this model. Is there a reason? The retract issue is a good debate and the join line on my fuse ruins which for the most part is a beautifull model.
Any advice about using or not using an OS engine would be appreciated.[&o] |
RE: Cermark F16 what engine?
a 91 fx with pipe would be great, jett would b even better, http://www.jettengineering.com/ (scroll down a bit after opening)
So what's wrong with with this 0S 91?
* 2.8 HP * multiposition NV * O ring seal on NV prevents setting creep and air leaks * Low profile = more cooling fins on head * Dual BB with the larger bearing in front Build the F-16, install the engine and fly it already. You might find this useful: http://www.rcmf.co.uk/4um/index.php?topic=67306.0 Bill |
Quite a few of the F-16 aircraft out there flying with OS91FX power. Nothing at all wrong with that combination.
There are a number of OS/Jett-stream combinations too in both the F-16 and F-18. Excellent combination. 12x7 or 12x8 prop, and you will really enjoy the performance. Lots of F-16s flying with Jett SJ-90L and SJ-90LX power too. Bob |
Well thanks for all the info . I'll have to have a think . I know the OS is a good reliable motor and with a Western tuned pipe will give a very good throttle response. I checked the price out at Steve web models resently and they've just increasd in price by £40 quid. The weak pound and import duty makes the Jett engine very expensive. For some reason I brought 3 of these planes. I'll post some pics and info once i get started.
| All times are GMT -8. The time now is 09:27 AM. |
