World Models clipped Cub
beware......the control horn for the rudder has to be trimmed OR installed "backards" so it will clear the fuse at full left deflection...
it also has te be mounted directly over top a metal hinge which is very hard to drill ,,,,IF you use their predrilled location. the metal hinge at the very bottom of the rudder projects thru the rudder post so far that you have to cut away some of the fuse tail-post so it will recess into the post... These are minor but I wanted the everyone to know...! |
Thanks for the "heads up"...
1 Attachment(s)
You also have to watch out for the strut attachment. The instructions for the plane are kinda a fuzzy in places. Otherwise, it's a joy to build. :)
The boy (pictured) has a Saito 72 four stroke in his. Unlimited vertical, very aerobatic! I've got another on like it that I'm putting together, except it's the blue one. Maybe I'll put the same engine on it! :D Best regards, Mike |
W-Models clipped wing struts
Are they functional ? Anyone flying without them ?
Wing struts....
Yep, the boy's plane flies very well without them. Flat spins..... no problem!
With the 72 in the nose, we had to move the battery pack behind the CG in order to get the plane to balance. The plane has a 1450 mha JR battery pack, Saito 72 four stroke, 5 Futaba 3003 servos. The rest is what the plane comes with....... Best regards, :p Mike |
They must have fixed this or something. I built mine stock and had no problems. The wing struts are optional but it looks odd without them. I had a hard time locating the strut holes in the wing but otherwise it was a easy assembly. It flys great! I built in flaps on mine and it has a SHORT takeoff run (20 feet or less) and lifts up like a helicopter. It was a easy add on and helps slow it down for easy touch and go's and landings.
RE: Thanks for the "heads up"...
Saito .50 enough for this plane? I have a Saito .50 just sitting around.
ron I fly mine with the Saito 56, plenty of power... vertical is not unlimited however it will do LARGE loops, stall turns, hammerheads and so on, if I yank the nose up at full throttle it will climb about 200ft before it slows to the point you have to fight to keep the nose pointed up... at about 230ft it's fully stalled. SLOW scale flight takes about 1/4 throttle...anything over 1/2 throttle is very unrealistic for scale. I'm not a float flier but I think it would have more than enough power. your 50 will have a bit less power... still more than enough for this Cub in my book. BTW I fly at 2500ft ASL
John |
Mine got its 3rd powerplant change (I love experimenting). It started with the O.S. 40FP then went to the thunder tiger .46 pro and now it has a older O.S. .61-FS four stroke. For this engine I also had to move the battery behind the CG. To be honest the .61 four stroke with a 12x6 prop has performance inbetween the .40 and the .46. The .46 definately had more power to weight ratio and pulled it verticle better. BUT the .61-FS isn't that far behind and has that beatiful 4-stroke sound. I bet the .70 surpass is the perfect engine for this plane. I think my .61 is about the same weight as the .70 but about 3/4 of the power.
| All times are GMT -8. The time now is 09:16 PM. |
