CA glue question?
This maybe a dumb question but, is CA the same as super glue?
Thanks |
RE: CA glue question?
Yes, slightly different formula, but the same stuff.
Dru. |
They are pretty much the same. I do like that CA comes in different consistencies though, and I think that CA is cheaper per fl.oz. than superglue too.
ORIGINAL: jayjast This maybe a dumb question but, is CA the same as super glue? Thanks Bill |
ORIGINAL: Ram Jet ORIGINAL: jayjast This maybe a dumb question but, is CA the same as super glue? Thanks Bill Yes, I won a few Fine Scale Modeler Shows too back in the 90's. Bet you can't guess what type of planes I built and competed in? :D I used Locktite a few times with a toothpick for my applicator... it works well with plastic models and I used Elmer's white glue as a filler. Then one day I tried ZAP and I was hooked! Use the good CA glue like ZAP, Great Planes or Mercury Adhesives etc. It has a slightly different formula and it absorbs into the wood better than the off the shelf super glues. Plus you can't get Super Glue in different thickness. It makes it easy to glue in the CA hinges if you use a thin CA with a long thin applicator tip. I use a Medium CA glue for all the non- high stress area's... like applying detail, adding a antenna to a Warbird etc. Hope I helped. |
ORIGINAL: LuftwaffeOberst ORIGINAL: Ram Jet ORIGINAL: jayjast This maybe a dumb question but, is CA the same as super glue? Thanks Bill Yes, I won a few Fine Scale Modeler Shows too back in the 90's. Bet you can't guess what type of planes I built and competed in? :D I used Locktite a few times with a toothpick for my applicator... it works well with plastic models and I used Elmer's white glue as a filler. Then one day I tried ZAP and I was hooked! Use the good CA glue like ZAP, Great Planes or Mercury Adhesives etc. It has a slightly different formula and it absorbs into the wood better than the off the shelf super glues. Plus you can't get Super Glue in different thickness. It makes it easy to glue in the CA hinges if you use a thin CA with a long thin applicator tip. I use a Medium CA glue for all the non- high stress area's... like applying detail, adding a antenna to a Warbird etc. Hope I helped. |
ORIGINAL: LuftwaffeOberst ORIGINAL: Ram Jet ORIGINAL: jayjast This maybe a dumb question but, is CA the same as super glue? Thanks Bill Yes, I won a few Fine Scale Modeler Shows too back in the 90's. Bet you can't guess what type of planes I built and competed in? :D I used Locktite a few times with a toothpick for my applicator... it works well with plastic models and I used Elmer's white glue as a filler. Then one day I tried ZAP and I was hooked! Use the good CA glue like ZAP, Great Planes or Mercury Adhesives etc. It has a slightly different formula and it absorbs into the wood better than the off the shelf super glues. Plus you can't get Super Glue in different thickness. It makes it easy to glue in the CA hinges if you use a thin CA with a long thin applicator tip. I use a Medium CA glue for all the non- high stress area's... like applying detail, adding a antenna to a Warbird etc. Hope I helped. Bill |
ORIGINAL: ram3500-RCU ORIGINAL: LuftwaffeOberst ORIGINAL: Ram Jet ORIGINAL: jayjast This maybe a dumb question but, is CA the same as super glue? Thanks Bill Yes, I won a few Fine Scale Modeler Shows too back in the 90's. Bet you can't guess what type of planes I built and competed in? :D I used Locktite a few times with a toothpick for my applicator... it works well with plastic models and I used Elmer's white glue as a filler. Then one day I tried ZAP and I was hooked! Use the good CA glue like ZAP, Great Planes or Mercury Adhesives etc. It has a slightly different formula and it absorbs into the wood better than the off the shelf super glues. Plus you can't get Super Glue in different thickness. It makes it easy to glue in the CA hinges if you use a thin CA with a long thin applicator tip. I use a Medium CA glue for all the non- high stress area's... like applying detail, adding a antenna to a Warbird etc. Hope I helped. It's clear that you don't know the Kaiser. Bill |
Bill,
the CA tips are open really easily with no effort if you leave them for the night in aceton. |
ORIGINAL: alex7403 Bill, the CA tips are open really easily with no effort if you leave them for the night in aceton. Thank you, Bill |
Yes, acetone, but put it in a sealed jar or by morning the acetone will have evaporated and your whole house will smell like nail polish remover
ORIGINAL: MinnFlyer Yes, acetone, but put it in a sealed jar or by morning the acetone will have evaporated and your whole house will smell like nail polish remover Thanks. Bill |
ORIGINAL: Ram Jet ORIGINAL: ram3500-RCU ORIGINAL: LuftwaffeOberst ORIGINAL: Ram Jet ORIGINAL: jayjast This maybe a dumb question but, is CA the same as super glue? Thanks Bill Yes, I won a few Fine Scale Modeler Shows too back in the 90's. Bet you can't guess what type of planes I built and competed in? :D I used Locktite a few times with a toothpick for my applicator... it works well with plastic models and I used Elmer's white glue as a filler. Then one day I tried ZAP and I was hooked! Use the good CA glue like ZAP, Great Planes or Mercury Adhesives etc. It has a slightly different formula and it absorbs into the wood better than the off the shelf super glues. Plus you can't get Super Glue in different thickness. It makes it easy to glue in the CA hinges if you use a thin CA with a long thin applicator tip. I use a Medium CA glue for all the non- high stress area's... like applying detail, adding a antenna to a Warbird etc. Hope I helped. It's clear that you don't know the Kaiser. Bill |
ORIGINAL: ram3500-RCU ORIGINAL: Ram Jet ORIGINAL: ram3500-RCU ORIGINAL: LuftwaffeOberst ORIGINAL: Ram Jet ORIGINAL: jayjast This maybe a dumb question but, is CA the same as super glue? Thanks Bill Yes, I won a few Fine Scale Modeler Shows too back in the 90's. Bet you can't guess what type of planes I built and competed in? :D I used Locktite a few times with a toothpick for my applicator... it works well with plastic models and I used Elmer's white glue as a filler. Then one day I tried ZAP and I was hooked! Use the good CA glue like ZAP, Great Planes or Mercury Adhesives etc. It has a slightly different formula and it absorbs into the wood better than the off the shelf super glues. Plus you can't get Super Glue in different thickness. It makes it easy to glue in the CA hinges if you use a thin CA with a long thin applicator tip. I use a Medium CA glue for all the non- high stress area's... like applying detail, adding a antenna to a Warbird etc. Hope I helped. It's clear that you don't know the Kaiser. Bill Ya vol! My girlfriend is 1/2 Goiman. Achtung! (know what I mean?) [sm=punching.gif] Bill |
| All times are GMT -8. The time now is 01:27 AM. |
