DP Ultimate Question.
Hi all.
For you DP Ultimate owners, I would like to know what servo's you all used. I have 4 9202 for the wings a 3003 for the throttle. But what would be good for the rudder and the elevator's? Any other tips for putting this bad boy together? |
i am running on a 6 volt system. Here are my spec for a 4.8 volt system.
45 oz on 4.8 wings 90 oz on elevator jr 8101 155 on rudder jr 8411 517 jr on throttle 2700NMHi battery, os-160 running various prop in the 18 x 6 -18 x 8, and 19 x 8 props. I pined the firewall with 1/8 dowels. Everything else was stock build. |
I will be running on a 7 volt system.
Cool.
You use JR how do you like the proformas? So far I have all Futabba. |
I use 9402's on rudder and elevator.
9402
Why do people say digital on the Rudder?
Holding power and precision
I use a HS5945 for the rudder on my dp ultimate. |
this is the system I am using in my DP
KOK3270 Gas Flight Pack Special 2
Part Number: LI-POGFP2 https://www.fmadirect.com/site/fma.h...roducts&cat=28 |
| All times are GMT -8. The time now is 03:07 AM. |
