| mark963 |
04-29-2009 11:18 PM |
RE: Wild Hawk fuselage
You can order replacement parts from Harbor Freight. Shipping is about $9 if you go cheap and I think the fuse is around $10-15. But one break??? Oh come on! I drove one into the ground at 75mph (according to the gps - my transmitter got wet and died) and it was ready to fly again in 3 days. One of these days someone might talk me into posting those somewhere. ;) Anyway, this is what you need to do: Heat the foam to about 150F. Too hot and it will get all dimply. A big pot of water on the stove with a meat thermometer is a good way to heat it. Hair dryers can sort of work. I'd bet that a hot car on a sunny day would do it, too. When it gets warm enough, it will relax back to the original shape. Then just use some UHU for foam for clean breaks and Gorilla Glue if you're missing some bits and you'll barely see the damage. Make sure to reinforce the front with strapping tape. Should be good for at least a dozen crashes.
