RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   the better prop (https://www.rcuniverse.com/forum/arf-rtf-75/8856544-better-prop.html)
alexedit 06-16-2009 11:22 AM
the better prop
Hi - I have an two cycle OS .61 and I would like to know. What would be the best prop I can use to pull some extra weight in my plane?
I am adding about 16 ounces of extra weight to my airplane and I want to get the best performance. Right now I am using an 11x7.5 prop, but I haven't added the extra weight.
any thoughts or ideas?
thanks
carrellh 06-16-2009 11:30 AM
RE: the better prop
I use a 12x6 on my ASP 61 two stroke and it flies my Uproar 60 very well.
A 13x4W would probably also work on my Uproar.
The airframe makes a difference so you should post more details.
Robotech 06-16-2009 11:33 AM
RE: the better prop
Try dropping to a 11X6. Assuming you're talking about a OS61FX. I generally prop them with a 12X6 but we don't know what your starting weight is.
MinnFlyer 06-16-2009 11:36 AM
RE: the better prop
Use a Graupner 11x7 or 11x6 - You can pull stumps with those things!
alexedit 06-16-2009 12:22 PM
RE: the better prop
Oh - the airplane is a Hangar 9 Frenzy - I had an OS 91 on it and it flew very well... but I am not interested in flying 3D I just want to do regular flying.
I flew it yesterday with the .61 not knowing what to expect and I have to say...I like how it flies with the 61 better than the 91. She feels lighter in the air and more trainer like which is what I am looking for.
I think she should handle the extra pound, I just wanted to know the best prop/engine combination for pulling the extra weight
exeter_acres 06-16-2009 01:20 PM
RE: the better prop
I use a 13x4w on mine........
jaka 06-16-2009 02:38 PM
RE: the better prop
Hi!
12x6, 13x4, 13x5 or 14x4W all APC!
Forget a small 11" prop!
outdoorhunting 06-16-2009 03:58 PM
RE: the better prop
Getting rid of some of that dead weight would also help it fly better. You might be suprised how much lead you can get rid of by moving the motor forward on the mount rails even 1/2" if you have room.
opjose 06-16-2009 04:46 PM
RE: the better prop
Yeah, why the extra weight?
If you've flown it already with the .61 then the C.G. is not an issue.
What is the extra weight for?
alexedit 06-16-2009 09:31 PM
RE: the better prop
the extra weight is a lipo battery for a camera system. the camera and transmitter are only like5 ounces more, but the batteries are provably 12 ounces ...at least
TomCrump 06-17-2009 07:09 AM
RE: the better prop
More diameter and less pitch should get you what is needed.
If it were me, I'd go with something like a 13X4.
