RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Hobby Zone Super Cub (Problems) (https://www.rcuniverse.com/forum/arf-rtf-75/8868532-hobby-zone-super-cub-problems.html)
chris687 06-21-2009 02:52 AM
I got this Super Cub from Hobbyzone and it doesn't go fuel throttle... It just cuts off when I try to raise the throttle... I was wondering if this is the motor or ESC... I am a new to this hobby so I am just not sure... Any, help thanks...
-Chris687
Mr. Mugen 06-21-2009 08:12 AM
RE: Hobby Zone Super Cub (Problems)
Cycle your batteries. When new they do this quite often. Also check to make sure those cheesy connectors are making good contact or replace them with deans ultra's. Check out the thread here for more info http://www.rcuniverse.com/forum/m_4371835/tm.htm
Kevin
RedGN 06-22-2009 03:05 PM
If the battery is fully charged then it is the recevier/ESC.   If it is a battey problem, the motor will run at minimum throttle.  If the motor still cuts out and you have charged the battery then it is the receiver/ESC.
Hope this helps
rgm762 06-22-2009 05:19 PM
when are you trying full throttle? mine will "cut out" on take off if the ACT is on</p>
skawt01 08-19-2009 04:19 PM
My Super Cub, which is brand new, has been cutting out periodically only at high throttle.  Even with fully charged batts.  Something tells me it's a bad connection, but I don't know squat about these things.</p>
