RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Control throws for Something Extra (https://www.rcuniverse.com/forum/arf-rtf-75/8883795-control-throws-something-extra.html)
borabora22 06-26-2009 05:02 PM
Does anybody have the control throws for the SIG "Something Extra"? I can not find them on their website
ggraham500 06-26-2009 05:45 PM
RE: Control throws for Something Extra
Per GP instruction manual:
CG is 5 1/4" (133mm) from the leading edge.
3D Control Throws
If setting up your Extra 330S 1.60 ARF with 3D throws, you should be able to switch to high or low rate throws during flight in case you find the 3D throws too extreme.
3D Rates
ELEVATOR: 2" [50mm] up 2" [50mm] down
RUDDER: 6" [150mm] right 6" [150mm] left
AILERONS: 1-1/2" [38mm] up 1-1/2" [38mm] down
Hope that yhelps
borabora22 06-26-2009 07:48 PM
Thanks anyway ggraham. I meant the Sig "Something Extra" My brain was not engaged.
