RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   The perfect engine for a 1/4 scale Spacewalker? (https://www.rcuniverse.com/forum/arf-rtf-75/9257171-perfect-engine-1-4-scale-spacewalker.html)
blhollo2 11-16-2009 07:17 AM
I'm having a 1990's model1/4 scale 7.5LB Great Planes Spacewalker re-monokoated and haven't decided on what would be a good 2 stroker for it, I used to be fond of Super tigre engines until I bought my first OS engine 1.20AX needless to say the engine is awesome & easy to breakin...I'm trying to buy a good quality engine with decent power, but also one that is with in my budget, I've looked at OS 95AX, GMS 1.20,Super tigre G90's, and towerhobbies 75. 91fx. anyone ever have a spacewalker if so what size engine did you run on it?
dant-RCU 11-16-2009 07:34 AM
RE: The perfect engine for a 1/4 scale Spacewalker?
I still fly mine but with a TT .91 4-stroke. Only engine I have ever had on it.
Dan
blhollo2 11-16-2009 07:53 AM
yeah I've been told .91 4strokes are perfect for this plane, but I perfer 2 strokes.
Rudolph Hart 11-16-2009 08:00 AM
Sheesh you guys have got it easy i reckon.looking for same so i can stretch the legs on a 220 saito:)
blhollo2 11-16-2009 09:19 AM
220 saito!!! might be a bit overpowered?
TomCrump 11-16-2009 10:08 AM
I have a Magnum 1.60 twin in my Sig 1/4 scale Spacewalker.
A match made in heaven ! :D
blhollo2 11-16-2009 10:11 AM
WOW!!! is it very nose heavy??? seems like a hoss! I do like have my planes over powered, thought about an 1.20AX too....I like unlimited vertical :D
TomCrump 11-16-2009 10:27 AM
1 Attachment(s)
ORIGINAL: blhollo2
No, she balanced with the battery pack installed under the fuel tank.
I have to admit, it did surprise me, as I expected the SW to be nose heavy with the twin.
blhollo2 11-16-2009 10:57 AM
thats very cool..nice paint job!
blhollo2 11-16-2009 11:08 AM
not much prop clearance!
Meesh 11-16-2009 11:51 AM
1 Attachment(s)
I have a Saito 90 twin cylinder in mine. The cylinders stick though both sides of the cowl. Looks very scale like.
blhollo2 11-16-2009 02:16 PM
Thats a nice looking airplane I do like how the engine fits too
TomCrump 11-17-2009 04:08 AM
ORIGINAL: blhollo2
Ya, unfortunately, you are correct. [&o] It's an 18X6. I may switch to a 16X8 to give me a little more room.
cloudancer03 11-17-2009 09:58 AM
may as well add my 2 cents..I am building a spacewalker2 and its going to be powered with my satio 150.I really am looking foward to it.
Meesh 11-17-2009 11:13 AM
You'll shake the fuselage apart with the 150
My $0.02
Bob
TomCrump 11-17-2009 11:52 AM
I don't think so, Bob.
He's building a Sig SW. The fuselage builds into a strong structure.
Meesh 11-17-2009 12:48 PM
1 Attachment(s)
OK Tom,
I thought it was the GP model he was talking about. A buddy of mine built the big Sig Spacewalker and put the OS Pegasus 320 4 cylinder in it.
See the pics!
Jetdesign 11-17-2009 01:57 PM
That 4cyl is absolutely beautiful.
Thunder Tiger just came out with a 1.30 four stroke.
Meesh 11-17-2009 02:15 PM
It is beautiful. He later installed baffling to direct the air to the cylinders like on a full scale plane.
TomCrump 11-17-2009 02:22 PM
Bob: I'll bet that motor sounds great, too !!! Your friend did a nice job, splitting the cowl.
Until recently, I was considering building the Sig 1/3 Spacewalker, and modifying it to be powered with a Saito 450.
I found another project for the 450, but I may still build the big SW. If I do, I'll power it with my Saito 300 twin.
Meesh 11-17-2009 02:33 PM
I had a 300 Twin. Sounded like a Harley with hot cams when it was idleing. Awesome!
The 4 banger he has is smooth and quiet.
Rudolph Hart 11-17-2009 03:32 PM
Bob that 90 twin looks good,which kit is it?
Meesh 11-18-2009 07:16 AM
Fart,
It's the Great Planes ARF.
Very relaxing flyer!
Bob
cloudancer03 10-05-2010 08:11 PM
it's been awhile since anyone including me posted.I finished my spacewalker and am concerned that my satio 150 might be a tad small as the plane dry weight is just a bitover 12 pounds.so with fuel it will come in near 13 pounds.this is a sig spacewalker 2..Is this bird going fly well or it be a struggle lugging it around.not expecting a bigtime aerobatic fler but dont want it to fly around like a model a either.should I be going with a gas engine??really discouraged as I thought I would be under 12 with fuel..
ispirit99 10-07-2010 05:49 PM
I am flying an Aero 28cc Gas in my Seagull 1/4 scale Space Walker with Jtech style wrap-around muffler. Didn't need any nose weight. She will do any manuver I put Her thru. Even hang on the Prop. The Aero 28cc is one heck of a motor and cheaper than the Zenoah 26cc. It hasa rear carb and weigh's less to.Didn't even have to cut the Cowl except the bottom for the exuast pipe's.Tony.
