RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   DP Edge flying weight (https://www.rcuniverse.com/forum/arf-rtf-75/961326-dp-edge-flying-weight.html)
3Dreaming 07-15-2003 11:57 PM
What is the all up flying weight of you DP Edge? Please tell what equipment you have on board. I have a ZDZ40 that I took off a DP extra that needs a good 3D home. Tom
edgeguy 07-16-2003 02:37 AM
My friend has this plane and it weighs in at 15 pounds. Here is his setup
OS 160 FX with Bisson pitts muffler.
Hitec digital servos. 1 on each aileron, 1 rudder, and 1 elevator. Pull-pull on rudder and elevators.
TME smoke pump with 12 ounce smoke tank and 600mah battery for smoke pump.
1650mah 6 volt receiver battery.
30% lifelike pilot figure.
Mejzlik 18X8 prop.
CG set at 5" behind leading edge of wing. the manual says 6" behind leading edge but was WAY to far back.
Plane flies great!!!
Kelly D 07-25-2003 08:05 PM
My DP edge is at 15lbs.
DA-50 on the nose with stock muffler.
Mejzlik 22-8 with a 3 1/2 Dave Brown spinner
Servos as follows:
Dual elevator servos (Multiplex Royals)
Dual inline rudder servos (also royals)
Aileron servos are Mulitplex Jumbo Speed
Throttle is a JR 368 mini digi, and choke is a Hitec hs-85BB
Rudder servo mount tray, aluminum
All carbon fiber push rods, with titanium ends
JR 1400 4.8v pack for ignition NICD
2700 6.0v pack for reciever NMHI
Kelly
edgeguy 07-30-2003 01:43 AM
Kelly, boy you must have done some lightening!! Or maybe your scale isn't too accurate.
We weighed this one on a certified scale. I sure don't know how yours came out the same with a heavier engine, and lots more servos and pushrods.
Or maybe you just got a lighter airframe.
Kelly D 07-30-2003 03:07 AM
Not sure, it is what it is. Weighed things piece by piece, on a digital scale, accurate to the gram. Maybe I got lucky. It does fly very light.
edgeguy 07-30-2003 09:19 PM
That sure is nice to have one that flies good and comes out light.
Good luck with your edge, and ENJOY!!!
