first autogyro set up help ?
I picked this plane up used, I have no plans or manual,or even a name, it has a os 25, I could use some help with cg .radio programing,cyclic inputs,engine thrust ?
any body have set up specks?
I tried flying it, all it would do is tork over to the right on the runway before lift off ?
Thanks dennis
Thanks dennis
FL
Dennis,
If you email me at [email protected] I will see if I can help you.. Maybe some one will come along and type everything you need.. I will give you my phone # and we can talk you through it.
Jim
Jim
try here all you need to know
sounds like you are not getting full lift from blades
<a href="http://www.modelflying.co.uk/forums/postings.asp?th=81671" target="_blank">www.modelflying.co.uk/forums/postings.asp
<br type="_moz" /></a><br type="_moz" />
