Go Back  RCU Forums > RC Helicopters > AutoGyros
Gyro Shtick >
Gyro Shtick
AutoGyros All about autorotational flight, sport and scale autogyros! User friendly!
Gyro Shtick
Old 04-02-2002 | 12:37 PM
Default Gyro Shtick
Jim
You made the right choice! Please post a picture of your completed machine!
Randy
Old 05-06-2002 | 11:12 PM
Default GyroShtick Flys
Randy,
I did fly the Gyro Shtick today. Engine quit early in the flight but landed OK. Will work on the engine tomorrow and try again.
Going to pick up a Cierva C-4 this weekend to build.
I have been waiting for some wind and finally got some today.
Jim
Old 05-07-2002 | 01:39 PM
Default Gyro Shtick first flight
Jim,
Congratulations on your successful first flight! Let us know how it goes when the engine runs properly!
Randy
Old 09-10-2002 | 11:11 PM
Default Gyro Shtick
Randy,
I plan on taking my Gyro Shtick to Martinsville,In. this weekend.
I did have a fairly good breeze today but could not get the rotor to come up to a good speed. My other gyro's spin up fairly good.
Any suggestion's?
Old 09-11-2002 | 12:27 PM
Default Gyro Shtick Autorotation
Jim,
Its hard to guess without seeing the machine just what might be the problem! Start at the rotorshaft and work up. How are the bearings? Insure there is no binding and lube the bearings with some Marvel Mistery Oil. I never tighten my blades on the hub too tightly. They should be free enough to seek their optimum lead/lag angle. Inspect the blades carefully to be sure the airfoil is fairly accurate. It is also important that the blades all have about the same airfoil. Also make sure the blade surface is smooth and shiney.
If all of the above don't do it, try adding a bit more negitive incidence to the blades. I was able to get mine to spin up using just a large box fan!
Good luck, Let me know what happens!
Randy
