GyroBot 900
<font size="2">The GyroBot 900 is a very high quality and precise controller and stabilizer for the swashplate and tail rotor of a model helicopter (three axes). It allows you to fly each </font><font size="2">helicopter with a 'rigid' head version, you no longer need a flybar and a tail gyro (But you can use a Flybar in Beginner- and Beginner Acro Mode)! </font><font size="2">All electronics are contained in one small housing (32x32x16 mm). You have more power and flying time.</font><font size="2">
</font><font size="2">The System can be used in the following modes:</font><font size="2">
</font><font size="2">1. Standard Mode</font><font size="2">
</font><font size="2">This Mode is a very precise control for flybarless helicopters. The model flies like a flybar helicopter, but without the disadvantages of a flybar rotorhead. That means </font><font size="2">there are absolutely neutral flying characteristics for beginners, perfect FAI, extreme 3D or very stable and precise Scale flying for 2 and multi blade rotorheads. Each multi </font><font size="2">blade head or 2 blade head flies “like on rails” with very easy adjusting and programming.</font><font size="2">
</font><font size="2">2. Beginner Mode
</font><font size="2">In this mode there is an active tilt control for the aileron and elevator axis. That means if you loose the aileron or elevator stick the GyroBot 900 moves the model back to the </font><font size="2">horizontal position. The maximum tilt angle of the model can be adjusted from 10 to 50 degrees, so the model does not tilt more than this angle. So a very easy learning of </font><font size="2">hovering and flying of model helicopters is possible now. The Beginnermode can be overridden from you (adjustable), so you can habituate step by step to the flying of a </font><font size="2">“normal” helicopter. The Beginnermode works in helicopters with and without flybar.</font><font size="2">
</font><font size="2">3. Beginner Acro Mode
</font><font size="2">This mode offers added to the features of the Beginnermode the possibility of easy learning rolls, flips, loops and inverted flying. If you tilt the helicopter more than </font><font size="2">90 degrees, the GyroBot 900 moves it to a stable inverted hovering position, never mindhow long you keep the stick inthis position. In the inverted position there is also </font><font size="2">an active tilt control if you loose the aileron or elevator stick. Also the Beginner AcroMode works in helicopters with and without flybar.</font><font size="2"></font><font size="2">The GyroBot is the only system using three acceleration sensores added to the 3 MEMS gyro sensors of highest quality. So it can recognize much more movements</font><font size="2">during flight and process themvery fast. That means for you: Perfect flight characteristics without adusting very long. The GyroBot can also be adjusted from absolute </font><font size="2">beginners very easily. You can do this via the “Cockpit” programming box or via the USB Interface Cable and the PC.</font><font size="2">The “Cockpit” can be both connected only for programming or fixed in the model.</font><font size="2">
</font><u><font size="2">Technical details:
</font></u><font size="2">-CNC manufactured aluminum case; bright chrome finish
-Measurements: 32x32x16 mm,
-Weight: 20 g</font><div><font size="2">-Sensor Elements: 3MEMS gyro sensors of highest quality, added 3 acceleration sensors ,
-RISC processor, Voltage range: 3,0V – 12 V,
-For all motors (electric, turbine, </font><font size="2">IC, gas) and all helicopter sizes.
-Optimized Functions for Multi blade Rotorheads
-Swashplate Rotation, Pirouette Optimization
-The system will always be updateable without loosing your existing settings.
-You can switch between 3 different flight settings via a </font><span style="font-size: 10pt">switch on the transmitter.
-Very easy programming, so you find the first setting in less minutes.
-Compatible to all PPM, PCM, and 2,4 GHz RC Systems
-Made in Germany
Price in Singapore $1,200
-Made in Germany
