Autogiro
2 Attachment(s)
Hello. I started my new project, It is Hal from Bolt's Autogiro, an old plan of Uncle Willie. I have experience in aircraft construction, but not helicopters. I have a question. The rotor features the 3/8 X 1/2" maple blade hanger with a 6 1/2° cut at the end of each, below the hole of the fastening bolt. Does this notch mean that the blades should not be fixed on the aluminium rotor hanger, but should be moved 6 1/2° freely? I send the plane and pictures for clarity. Thanks in advance for your comments.
https://cimg7.ibsrv.net/gimg/www.rcu...b3e29a7c16.jpg https://cimg8.ibsrv.net/gimg/www.rcu...4931cc7bc3.jpg |
Hello. I finished my gyroplane and I did everything the same as the plan. When I started the engine, at full capacity, the rotor moved very slowly. The plane marked 500 RPM and my rotor was 50 RPM. What can be wrong?
| All times are GMT -8. The time now is 06:20 PM. |
