need help
need help please,i have a db models ,double rotor autogyro
from the 1970 s I loaned the plans ,and never got them back ive been trying to get it flying again but its been a long time since I last flew it .I cant remember where the cg was suposed to be.I would be gratefull for any information.[:o] thanks kenny, |
RE: need help
Hi. Can you post a pic of it?
RE: need help
I have the RCM&E magazine dated November 1987 which has the article on the DB Gyrace. The CG is about 25% of the way back from the LE of the wing - no more!
Colin |
RE: need help
Thanks thtoyman.Icant post pictures,I havent got that far
with computors yet. Thanks Colin.I will try 25%. from what i can remember it was very criticle of the cg.The gyro had a small wing\ about 25 ins span. The rotors 4 blade 24 ins dia. The rotors are at each end of the wing,on the leading edge. It also has a T tail. thank you , kenny. |
RE: need help
Aditionaly
I had been told by someone That it should balance at the rotor shaft, but that does not work,It flys like its nose heavy. 3 feet off the ground with lots of up elevator.Give it more up and it mushes into the ground.Ill try 25% and see. |
RE: need help
tintrax
HI . Any way you can post it here? |
RE: need help
1 Attachment(s)
Here is the best I can manage. Note that this is David Boddington`s `Gyrace`, not the plane referred to above, but same principles guess - & same designer. Fold in magazine page does not help the scanning either, the CG is shown by a small triangle about 1/4 way back from the LE.
Hope this helps. |
RE: need help
Thanks. It does help alot.
RE: need help
Larry,
It's right where I told you it was. Good Luck, Jim |
RE: need help
Hi Jim. Just re checking. I lost where I wrote it down at. Keep a eye open for the US mail. any day now. Thanks
RE: need help
Looks good,will try the old one and a new lighter version.
this weekend . thankyou .kenny. |
RE: need help
cg is 73mm back and throw 15mm on ele and 20 mm on rudder with blades turning in to the middle
just incase any one new looks at this post but great to fly |
| All times are GMT -8. The time now is 06:04 AM. |
