new E gyro
Here are some pics of my new little gyro. it has a himax 2812-850 motor a 10x3.8 apc prop. Castle creation 18 amp esc and a vampower 1320 3 cell Lipo. AUW 19.1 ounces. its a little heavy but i didnt use carbon fiber either.
The fuse is pink fanfold insulation and the fuse bracing/ spar is a piece of 1.5x.25 lattice cut down to .25x.25 X 24inches. The mast/ boom is also lattice cut down to 3/4 inch wide X 29 long. about 10 Degrees diheadrial. The rotor hubs are gws 400 gear boxes and the rotor bades are 4 strips of 4mm coroplast cut 2x12 inches. i also uses peices of the 4mm to shim the TE of the blades. left blade turns clockwise right turns counter colckwise. both outside blades are the advancing blades. It doesnt work well with the blades reversed. it wont fly straight or turn to the right hardly. it flys great like it is. The wind is rough today so it doest like it too well. Its abot 13 with gusts. The prop is too low in pitch i think. its drawing 10 amps at WOT i need more pitch speed but still good thrust. Can anyone reccommend a good prop for my motor? http://image.rcuniverse.com/gallery/...1/lg-77445.jpg http://image.rcuniverse.com/gallery/...1/lg-77446.jpg http://image.rcuniverse.com/gallery/...1/lg-77447.jpg |
RE: new E gyro
So you fly it yet? How the blades work?
RE: new E gyro
yes i flew it. They spin up easliy for a hand launch
