New From Yomoko!!!
New Items from Yokomo for the DRIVE M7 ADVAN MAX ORIDO Racing 86 and Yokomo DB7!!
The new Yokomo DRIVE M7 ADVAN MAX ORIDO Racing 86 Light Bucket Set and Plastic Part set ready for you if you want to make your drifter to have the DRIVE M7 ADVAN MAX ORIDO Racing 86 look
DRIVE M7 ADVAN MAX ORIDO Racing 86 Parts
![](http://i1067.photobucket.com/albums/u433/waynemeyernz/SD-M786L_zpsf4ddc62d.jpg)
Also New an hot is a Great way for fine tuning your Yokomo DB7 Beast
Is the new Aeration Shock Cap and new 2 and 6 Degree Caster steering hub set!
![](http://i1067.photobucket.com/albums/u433/waynemeyernz/B7-S6AC_zpsf54ff664.jpg)
New Yokomo DB7 Tuning Parts!
the new Aeration Shock Cap is a Prefect way to fine tune your dampers to suit the tracks needs to give max performance.
Also with the adding of the new 2 or 6 degree caster blocks to add levels of much need grip or less grip depending on track conditions!
Please come join us on Facebook for Weekly updates and Specials!
Banzai Hobby Team
Banzai Hobby Team
Kingpin Angle Front Steering Block
By offsetting the kingpin of the upper and lower angled to kingpin axis, is steering block is changed to positive camber, such as vehicle tires counter steer outside when you turn off the steering wheel. It is also possible that the affinity with the counter drift is good, traction of the front up in the ground plane change when you turn off the full steering and make driving a controllable. The lineup of the two types 12 degrees and 10 degrees, you can use it according to the situation kingpin angle.
![](http://i1067.photobucket.com/albums/u433/waynemeyernz/SD-415S10_zps0d988aa4.jpg)
