venom pro charger-cell block balancer
AR
Ok i'm new to lipos. I have a venom pro charger that came with cell block balancer. I purchased a flight power eon x30 2200mah 6s 22.2 v battery. The battery has a deans connector and 2
other plugs. I assume the deans plugs into your charger and the other 2 are supposed to plug into the balancer. But the 2 balancer plugs dont match up with the cell balancer pins. They dont
match up, they wont plug into balancer??? What am I missing here?? Do different brand batteries have different size balancer plugs?? Anyone with the same setup have suggestions??
Thanks for any info
Thanks for any info
My Feedback: (9)
RE: venom pro charger-cell block balancer
Welcome to the world of no-standards. Yes, there are several different balancing plugs. My brain isn't in full gear right now, but there is a site that shows what style of balance pins the major Lipo suppliers use. You will then have to get the proper adapter.
Try a form/topic search her and in wattflyer.
Walt
Walt
AR
Thanks for the replies and link.
Wow this just got more confusing about different board adaptors and such. I guess I will goto the not so local hobby shop and see if they have anything that will work.
AR
Well just to follow up on this I contacted Flightpower (which is probably what I should have done in the first place) and was told I needed this adapter FPWM0169. And of course I can't seem to find anybody that has them in stock.
[link=http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=++&FVSEARCH=fpwm0169&search=Go]Flightpower 6s adapter for venom charger[/link]
