simultaneous charging
TN
will the Triton charge only one battery pack at a time or can it be set up to charge both your transmitter and receiver packs simultaneously given that both packs have the same capacity? THANKS, Jake
Does that charger have two charge outlets? My charger has two seperate charging hook-ups, one for each battery pack you wish to charge. I assume though that you are asking if you can hook the pack in series or something and charge them with one output from your charger?
