External LVC needed.
I'm looking to get an External LVC for my Boat,I'm running a Seaking 180 Amp ESC and the LVC kick's in all the time,my pack's are fine and are Thuder Power and Turngiy's and have the highest C that each one make's.
I seen Novak make's one but it just buzz's or something like then you need to come back to shore and the problem is I'll never hear it,I found this one but they are set at 3.0 Volt's Per-cell and I would like to find something with a CutOff set at 3.2 Volt's Per-Cell.
PA
ORIGINAL: wade7575
With your problems of high current an need for programmablity
Look into telemetery, solve all problems at once. some are even reporting to cell phones.
Rich
Richrd when you say telemetery what do you mean I don't understand,is that the type of LVC I need to get or is it some other kind of device I need to buy.
Here's a link to the one I found I thought I posted in this tread the first time but I guess not.
http://www.dimensionengineering.com/products/liposhield
Thanks for the help.
Wade
Wade
PA
http://www.hobbyking.com/hobbyking/s...dProduct=10343
this is a transmitter in the vehical to send info back to radio or as above seperate device, spectrum, hitec eagletree all make them
Richt
Richt
CA
ORIGINAL: wade7575
I thought all ESC would.
It does have an adjustable LVC but they are not the greatest out one's ever made that were built into an ESC,I was running 2 7.4 Thunder Power pack's in series for a total of 14.8 volt's,I'm going to try running 2 14.8 Pack's wired in parallel as I was told that if you do not have enough Amp's it will just make the LVC trip all the time,I'm just looking for a back up plan incase this does not work.
I'm really olny looking to use an external LVC if the 2 14.8 Pack's don't work,I think the 2 14.8 should work as other guy's on another well known forum say that they seem to run really good on that set up.
