Cellpro 8 accessories needed to daisy chain 2 MPA boards
Hello
As in the heading is like to buy a cellpro 8 and 2x MPA boards to be able to charge at least 8x (4s) packs at the same time. I run 2x 4s 5000 mah packs in series to form one pack (8s).
it says I can daisey chain these together in the MPA advert but can't find details of it.
what other items do I need ( apart from a cellpro8 and 2x MPA boards) if any?
Regards
rodders
Regards
rodders
One MPA to MPA cable
This looks like the correct one , Even though it says MPA to other, etc.
http://www.usastore.revolectrix.com/...2/MPA-XH-X10_2
I forgot to mention the possible need for an additional Banana Plug main battery charging cable or extender.
You can make or buy. Powerlab does sell a pigtail with the 40A fuses installed in line, and the fancy banana plugs.
(I'd make one for my use if I needed it!)
A problem I see with using two MPAs is basically real estate. I have enough trouble
with bench space for one MPA and 6 attached lipos. Recently, I purchased a DPL-8 with two MPAs, and this shows
how much space can be needed.
Hello
Regards
rodders
Regards
rodders
You can use coupon code bisb14 to save 10% on chargers, LiPos, and accessories when ordering from the Revolectrix.com website.
http://www.revolectrix.com/cellpro_adapters.htm
Hello
Regards
rodders
Regards
rodders
The most obvious issue is that 2 4S lipos have two 4S balance connectors. These would need to be combined into one 8S balance connector,
with the 2 4S connectors in the correct order if you were to try to charge the lipos in series.
Parallel charging is what the MPA is designed for, and this eliminates the need and worry concerning a "y" combiner.
Charging 8 4S 5000mah packs in parallel - - -
At a 1C per pack charge rate this would call for a total charge current of 40A (Maximum rated charger charge current)
A 2C charge rate would require more than one charger.
Going back to a series charging scheme, only one charger and MPA would be needed. The however is that
adapter cable are needed for the power/charge connections to the Lipos.
You would end up with four 4 to 8 balance adapter cables, and four power/charge adapter cables.
The complexity is enough that the potential to have inadvertently connected things improperly is much greater.
This assumes that four pairs of two Lipos in series will be the charging configuration.
Hello
Regards
rodders
Regards
rodders
http://www.store.revolectrix.com/Pro...SPA/MPA-XH-X10
1 Post
Some MPA boards have wires coming out the board to add your own connectors for the batteries, the older MPA boards have deans connectors on the board and would need adaptors if your not using deans on your batteries.
