Charging discrepancy in instructions
I'm an experienced RC Car guy, but new to flight. I picked up a Dromida Vista for Xmas, and am having a good time with it. It uses a 1S Lipo battery. The instructions from Dromida say to charge the battery up after use. Um, doesn't this go against the leaving Lipos charged is not a good idea thing? Granted, the supplied USB charger isn't capable of doing anything fully charging the battery, but, with the supplied 850mah pack, the cut off voltage on the Vista is just about storage voltage. So, would it not actually be better to leave the flight batteries UNCHARGED?
Um, yeah, as far as I know that rule includes 1s lipos, though they may not be as sensitive. Whenever you have a chance, pick up some 1s lipo extensions, cut one end off and use it to charge from a normal charger. I just fly half as much as I normally would on the last flight with my inductrix, but the lvc on that is lower than nominal.
Hubert
Hubert
