Starter Battery
My 7 Amp gel cell starter battery has served me very well for many years but is just about belly-up...time for a new one.
I know some pilots, especially those with gas engines, use lawn mower size batteries but that's a bit large and heavy to lug around.
I've seen motorcycle size batteries (4 to 6 Amp) and was wondering if one of those would be better than a gel cell. More cranking power??
I have about 15 engines ranging in size from .075 glow to 35cc gas and everything in between so it's not that I need the added CCA every time except for the few gassers (which the gel cell would turn over, not very fast but adequate to start).
G42
My Feedback: (17)
Value Hobbies . Com has some very good prices on their stuff. I use their life receiver batteries, in all my planes. Check out their covering, 1 roll is big enough for most giant scale planes. I recovered my RC Guys Giant Decathlon and GP Giant Ugly Stick . Look through the site, you will see what I mean.
Rich
Rich
definitely need more than 12 volts with a Hobbico...... I tried two fully charged 4amp 12volt wet cell cycle batteries in parallel and both my Hobbico starters (one brand new, one older) would barely turn a Magnum .46XLS over when not hot......to me,..... that makes Hobbico starters pretty much useless. after experiencing that, I haven't even considered trying them on my .60's and that's what I bought the starters for.
My Feedback: (19)
Most people at my field use LiPo batteries for their starter. Often times these are batteries retired from flight use but still good enough for a starter. These batteries far outperform even new Pb based batteries that just don't have the current capacity that a good LiPo does. Yes, LiFe batteries would also work. I've used a Hobbico 180 for years and find it to be every bit as good as any Sullivan starter I've ever used or owned. The standard Hobbico starter is a wimp though. With the Horizon takeover, are any of the Hobbico starters even still available?
Edit: I see all the Hobbico starters as "discontinued" now so they become a non-issue probably never to be seen again.
the only thing I can say is that I have to try a higher amperage battery(s) next, but sure thought the Batteries I bought would be enough. there is no minimum amperage listed in the directions other than the 12 volt requirement, which both batteries are.
I hate to think I have to lug around a bigger heavier battery for them. the two batteries I have fit in my box nicely and aren't bad for a short haul. as far as i'm concerned right now,...these starters are garbage and Hobbico ripped me off for one of them.
One of the major issues with your 12v gel cell/Pb batteries is they just can’t supply the current needed. Try a 4S lipo of about
3300 mah (3.3ah) and watch your starter do the job. Even though the lipo is half the storage , it can supply the current and the catch is with little voltage drop vs the PB battery.
Shortening the power cord by mounting the battery to the starter also helps by reducing voltage drop.<br />I mounted a battery box to an old H9 starter and fitted a 25500 mAh 4S A123 pack, spins a 20cc like a toy!<br />Pete
As Pete says another alternative to a Lipo pack is the A123 systems Life pack as that one too can supply the required current with little voltage drop.<br />Also the wiring on all starters leave something to be improved on. If the wiring was shortened or 12 gauge silicone covered battery wire used ; that would help. Most starters use about 18 gauge wire.....too small.
Went into Harbor Freight (the Men's toy store) just to look around while the wife was shopping next door. Found an 18V NiCad drill battery and charger for about $20 thanks to my 20% off "super coupon". Works great! When that goes will consider a LIPO pack.
Thanks to all for the replies (above).
Now just need to start looking for a replacement for my Hobbico 90 starter. It has served me well for many years...even starts my DLE 35RA easily but it is aging.
The Nicad pack may work but won’t hold a close race with an A123 Systems Life battery or a lipo.... the A123 systems 2.2 amp or 2.5 amp cells can unload 55 amps plus continuous discharge , similarly with an adequate lipo.
