Hyperion 6061 “voltage too high”, “open circuit”
My Feedback: (21)
I’m having issues with charging 2s LiFe batteries only. It happens randomly but with certain batteries more than others. I’ve tried with and without the balance plug. It happens a lot more when I charge through a MPI switch/charge port. It still happens occasionally directly to the battery. All cells are balanced within .01 of each other and even when they are at 3.32 I get “voltage too high” sometimes “open circuit”. I read on another thread that another model of the Hyperion chargers probably blew a mosfet resistor. Could this be the case?
My Feedback: (21)
Not likely a "MOSFET" problem, a MOSFET is a transistor (Metal Oxide Semiconductor Field Effect Transistor) and like all transistors they usually do not fail in the way you describe. What your describing sounds more like an intermittent connection, perhaps the charge leads your using to connect the batteries to the charger. If the charger works fine on all other modes of operation my inclination would be to blame the charging leads or the batteries themselves. Both "voltage too high" and "open circuit" are indications that for whatever reason the charger has stopped "seeing" the batteries load, have you tried charging the batteries that exhibit the problem on a different charger?
