Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > Batteries & Chargers
 Using a Higher rated battery pack ? >
Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
Old 05-19-2004 | 07:15 AM
Default Using a Higher rated battery pack ?
I have an electric J3 cub which has a 400 size electric motor using a 8.4v,1100mah NiMh battery pack. Connected is a ESC (not sure of rating).
Could someone please tell me whether it would be possible to use a 2500Mah pack instead of the 1100Mah pack without causing damage to the motor or speed control ?
Also what would the effect be of charging the 2500Mah pack with the 1100Mah pack's charger, the charger is a slow charger taking about 3 hours to charge the original pack.
Any help wouldbe appreciated. Thanx
Old 05-19-2004 | 05:12 PM
Default RE: Using a Higher rated battery pack ?
yes , you can use the 2500 mah pack,but i will be heavier.the charger is ok but it will take more than twice as long to charge it
Old 05-20-2004 | 09:05 AM
if you have an 1100 mah nimh pack now, that is probably AA (or similar) sized cells, and the 2300 might be C or sub c, my point being there is a substantial weight difference, and your flight time, assuming you get off the ground, might not be higher. (you now have to run at full throttle 100% of the time just to stay aloft, whereas before you could have throttled back)
Anyway, try some of the 1600/1650 8 cell nimh AA packs. Fairly light and should give you a little more time.
