1650nimh Which charge rate?
I know that idealy I want to charge my new 1650mah NiMH Tx battery at c/10, however, I have three choices for charging 200mah on my Supernova with peak detection or 100 mah on a Hobbico multi charger constant charge no cutoff or 125mah on an Accu Cycle with a cutoff after 15 hours. Which would be the best for initial charge and normal charging?
Banned
My Feedback: (9)
Just set the SuperNova to charge at 100 mA and that should be a good conditioning rate. If it hasn't terminated in 24 hours, shut it off manually. Then cycle to see what you get.
