SuperNova and 750m AAA NiMh peaking out to fast
TX
I am experiencing difficulties getting my S.N. to charge my 750mil AAA NiMh pack. I though at first I was charging at too high of rate but I dialed it down to .2 Amp and it pops off at only 70-90 mil of charge. My pack charges just fine with my Hangar 9 Double Vision and that charges at 1C rate.
Whats up?
Whats up?
TX
Re: SN
Originally posted by echapkis
What you are experiencing is a well known issue with the Super Nova and NIMH packs. The SN does not properly peak nimh packs.
Who can I contact about this at the distributer level?
I believe we had a thread going on this once before and didnt you or someone else recommend using the auto mode or NiCad setting? It works fine on all my other batteries just not on these smaller cells. It could be the impedence of these smaller cells... hmmm!
Wayne
AR
Is FMA saying to use the general plug and play setting on nimh or something else? Reason I ask is that mine won't charge higher than c10 on any nimh.
TX
The more I hear about these concerns the more the Turbo chager Evans been talking about gets more interesting. However, I have already invested bucks in the S.N. My Hangar 9 Double Vision has worked flawlessly as a field and quick charger. It will not however discharge and display important info about your packs.
My Feedback: (282)
nimh batteries
I did some testing of 720, 1650, and 2700 nimh packs on the Super Nova and Super Turbo.
The results were mixed. I am running a 4 cell 2700 nimh pack in my heli's. My Super Turbo does peak detect the packs properly when I use a 1 amp charge rate. I recharge after every 2 flights. About 550 mah is put back into the pack after 2 flights which should be about right.
When I tested the 720 and 1650 on the Super Nova, they did charge correctly or close enough. The 2700 could never charge properly on the Super Nova.
What I think is going on is that nimh packs that do not properly peak may not have been "primed" properly before a peak charging started.
My technique has been to C/10 charge the new pack for 18-24 hours, then cycle on my Alpha 4. Sometimes 2-3 cycles are required for the pack to get to rated or higher capacity.
The first 3-4 charges are slow C/10 charges only. Once 3-4 slow charges are done, then I will use my Super Turbo to peak detect charge the pack.
I found on my 2700 pack is a 1 amp charge rate, setting the Super Turbo for 3000 mah (cycled capacity) it works fine. So on the Super Turbo I have been successful in charging 720, 1650, and 2700 packs.
I would suggest that anyone using nimh packs do what I explained above. I am not saying that this is the only way, but I have had consistant results with nimh packs doing the above procedures prior to peak charging.
TX
Re: nimh batteries
Evan... you may have answered my problem. I originally charged this NiMh 750 pack on my Hangar 9 Double Vision and not at C10 rate (more like 1C) so I did not properly form(prime) these cells.
Could I discharge these completely and try to recharge at C10 and then cycle a few times to (maybe) get it back to the proper peak detection?
They have been working just fine and charging OK on the Double Vision and hold plenty of reserve even after a full day of flying in my small planes.
FL
New NiMH packs do require several complete cycles to arrange themselves.
The peak detecting capabilities of the SuperNova for NiCD and NiMH are only .02 mV apart. (.09 and .07 respectively.) There is not a problem with the SuperNova's ability to detect NiMH peaks.
It is just more sensitive than others.
There is no harm in using a preprogrammed NiCD preset for use with NiMH. Just keep an eye on your pack the first few charges.
