Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > Batteries & Chargers
 mAh rating for standard alkaline cell ? >
Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
Old 08-07-2004, 11:41 AM
Moderator
My Feedback: (58)
rajul's Avatar
Default mAh rating for standard alkaline cell ?
Does anyone have any data on the mAh capacity for a standard 1.5V alkaline cell ? I'll be discharging a cell on my accucyle to get an estimate. Has anyone done this measurement ? Please share your data. Thx !
Old 08-07-2004, 12:17 PM
mr.rc-cam's Avatar
Default RE: mAh rating for standard alkaline cell ?
The primary cell makers do not follow the same parameters as is used to test NiCD's. They often use VERY low discharge currents (25mA) and a 0.8V cutoff.
Here is a typical AA cell. Rated at 2700mAH using 25mA discharge: http://data.energizer.com/datasheets...ready/a91b.PDF
Old 08-08-2004, 04:40 AM
Moderator
My Feedback: (58)
rajul's Avatar
Here's some results obtained from my Accucyle at 250ma discharge current:
Energiser (alkaline)...........1400mah
Eveready "heavy duty"..........330mah
Old 08-08-2004, 05:04 AM
My Feedback: (16)
What cut off voltage did you use and is it right for that chemistry?
Old 08-08-2004, 05:09 AM
Moderator
My Feedback: (58)
rajul's Avatar
Miles, it is a comparitive study, so I just left the accucyle to do its standard job. I can't change the cutoff of 1.05V
Old 08-08-2004, 05:35 AM
Ross Kean's Avatar
Your test shows a couple of the problems of using alkalines.
1) The effective capacity drops a lot if you discharge at a high rate.
2) The voltage drop as a function of remaining capacity and/or draw rate is much higher than NiMH or NiCd.
The discharge curve places a significant proportion of the cell rating below one volt where the effective power may be too low to run some equipment properly.
Ross
Old 08-08-2004, 05:43 AM
Moderator
My Feedback: (58)
rajul's Avatar
Good points Ross. It will be great if the discharge curve is available
Old 08-08-2004, 10:26 AM
No discharge curves, but some interesting info here (tested capacity of AA NiMh and Alkaline cells in DIgital Camera apps):
http://www.imaging-resource.com/ACCS/BATTS/BATTS.HTM
Old 08-08-2004, 10:53 AM
Moderator
My Feedback: (58)
rajul's Avatar
Thanks Pete. Great article comparing Nimh and alkalines !
Old 08-08-2004, 12:18 PM
mr.rc-cam's Avatar
The battery makers often have discharge curves available. The link I gave above shows the curve for the proposed example cell.
Old 08-08-2004, 10:07 PM
My Feedback: (325)
I use rayovac rechargeable alks and I remember correctly they ran about 360 mah for the AA
Can't quite remember the specs and cutt-off though.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
