? about charging tx battery
My Feedback: (7)
TN
I have a futaba 9cap and a triton charger........still haven't quite figured out this charger.
What settings should i use to fast charge this tx battery??? It's a 8 cell 9.6v 700mah
My Feedback: (16)
GA
RE: ? about charging tx battery
I would use 700ma to charge it.
ORIGINAL: tstanfill
My Feedback: (41)
That's what I do.
ORIGINAL: Geistware
ORIGINAL: tstanfill
My Feedback: (19)
NY
Using the Triton's Nicad peak charge routine, the charge rate is .7 (that's POINT 7) amps. This rate is also called '1C' and it's a safe rate to fast charge a 700ma NiCad OEM AA pack while at the field.
Slow charging (10% rate, 14-16 hours) is 70ma.. and the tritions lowest setting is 100ma (.1), so the Trition might not be your best option for normal slow charging. Probably your best option for routine maintainance slow charging of your OEM 700ma Tx pack is the wall wart that came with the radio set.
Hope this helps!
Hope this helps!
