Battery Charger UNSURPASSED!
#76
My Feedback: (31)
Sirius chargers
The Pro Charger is not designed for NiMh use unless it has been factory upgraded. The Limited Edition is capable of charging either 4-5 cell NiCd or NiMh packs.
The LE unit will charge a completely discharged battery within a 45 minute time frame generally depends on the size...
The Pro unit will charge at a much slower rate 1-3 hours depending again on size.
Neither of these units will charge a flat battery. I have had several instances when I had to use a conventional wall charger or something similar to get a battery up to a level of charge, prior to them working charging on the Sirius equipment.
Another consideration when using Sirius Equipment is the need for the voltage to be move through the charge jack in both directions, many TX's have a diode installed preventing the Sirius equipment from functioning. You either disable the diode, directions on Sirius site or remove the battery from the TX and charge.
#77
Banned
charge
I think we are both saying the same thing...I would suggest on a new batt to charge the 15 hours as suggested , and the enjoy the sirius...I do not suggest the pro for what he intends to do...........Regardless you will be very happy...
Regards
5
Regards
5
#78
Banned
accucharger
This will get you on the playing field.......just follw directions on whatever you use...The Sirius charger is built for me!...idiots...I cannot make a mistake,,,
#79
I have always used the wall warts and such that came with the radio but when I set up the radio in my B-17 I needed a lot of batteries and special chargers. I talked to Sirius and bought the reg size (pro) for my two 800 rx batteries and the limited (bigger with two fans) for my two 2000 six volt packs.
When I go to an event I am usually motel bound and really don't want to take a 70lb B-17 into the room to charge it. In the morning I get in the Suburban, hook up the small Sirius and charge. When the lights blink I stop, hook up the large sirrus and charge. When I get to the event my batteries are charged.
After each and every flight I recharge all batteries using the Sirius chargers. I also check the batteries before and after each flight.
I am now free from the nightly hook up in the garage and the "hope I can find an outlet" at the event. Heck one time in Omaha at the motel with my Stearman I ran an extension cord from the room to the truck. No more the Sirius does it on the fly.
I bought the chargers for my B-17 but now use them for all my planes including my 40 sized Morris. I don't worry about forgeting to charge I just charge when I fly, not the night before.
I also have the Sirius Super Test that drains the bats and gives you the capacity. So simple, no plug in, I can use it anywhere, anytime. Sirius has made it so simple.
Paul
Paul
#80
My Feedback: (48)
Re: Sirius chargers
I just pulled up the Sirius web site and they say the pro does nicads and nimh.....so they must be selling the updated version. Is this charger more suited though for nicads than nimh? I'm simply searching for a way to manage my batteries easier, because I never know what i'm going to fly next ( I have my on airstrip on my property) and I have a choice of 15 planes to fly ranging from 20 - 120 size
#81
My Feedback: (31)
DLT
You are correct they do state the Pro is now capable of NiMh cells. Previously they had to replace the chip to increase the charge rate and sensitivity to utilize NiMh cells with the Pro unit.
If you have an older Pro unit this is still the case, per the manufacturer.
These are exceptional user friendly, goof proof, safe to chare indefinitely units. I would without a doubt use the Sirius equipment... There are only a few units with comparable conditioning schemes on the market.
#84
My Feedback: (48)
Re: DLT- What,Where, and How Much
No problem......I bought it at Radical Rc (go to their web site and get the phone #, also great place to buy batteries).It was $115 for the Pro model. They have good prices on batteries and i'm switching to nimh for the most part, mainly 1650 mah (Sanyo's)
Originally posted by gbagley
May I ask where you got it from and how much was the Total shipped to your door.
-gerald
-gerald
#85
My Feedback: (48)
OfficeShops.com
Nice to know about you Gerald.....one of these day's i'm going to delve into electrics or at least that's what i've been saying for a couple of years or so. That Tiger Moth looks very interesting.
Dave
Dave
#87
IL
Gerald-
Am I correct in that you do not accept credit cards for orders?
I've successfully used PayPal before, but have heard that it has caused problems for some people.
Got your site bookmarked.
Karl
Karl
#90
IL
Gerald-
Not a criticism, but just wanted to be clear on that. I don't think that fact alone would keep me from ordering from you. I fully understand why you do not take plastic, but if I were to place a VERY large order, I'd prefer the protection that a credit card affords the buyer.
Our local hobby store is severely e-flight challenged, I'm 0 for 5 now on items that I have tried to find there. So, I'm forced to look for mailorder suppliers that can ship small orders without too much handling cost. But on the other hand, I don't like waiting. Sending orders through the mail isn't an option. For some reason, we have the slowest mail delivery in the country. My record so far is 21 days for a first class letter from TX.
As I mentioned, I have your site bookmarked, and will likely be placing an order soon (using PayPal).
Karl
Karl
#95
#96
CA
technologyand outdated equiptment
And to think I have been using a Hobbico multi charger for years with no problems at all.
You guys know the best thing about technology? Well, in a short time something better will undoubtedly appear putting most of this thread to rest. Or until FiveSquare gets wind of it.
PS. to MGlavin (post #57) could not have said it better myself!
#97
SC
Here are my stable of chargers:
1. MEN Charger: For my transmitter and receiver nicads, I use a MEN pulse charger. Has all the features of the new charger except I don't think it can be used for the nickel hydride since they were not available in the early '80s as far as I know.
Bought the first charger in 1983......been going strong ever since.
I picked up two more brand new in the box a couple of years ago at the Perry Swap Meet in Perry, Georgia for $20 bucks a piece......couldn't believe it.
Reason why I got them so cheap is the company MEN is now our of business and all you hear about today are the Sirus......so people were walking by probably wondering what a MEN charger was.
2. ACE charger: I also use the ACE multi charger to maintain my transmitter and receiver nicads. It has a trickle charge and a fast charge rate.
3. JETI charger: For my electric planes, I use the JETI field charger. Paid $35 for it and hasn't failed me yet.
It charger both the nicads and nickel hydride.
Goes into tricle once the batteries have peaked out.....can't want much more than that.
4. Hobbico charger: I carry and use the Hobbico field charger if I plan to be at the flying field all day. That charger is used specifically for my transmitter and receiver nicads for the times I plan to be at the flying field all day.
Paid $19 for it.
5. Thats my stable of chargers.
Nothing fancy or expensive.....
But I have to tell you, although I don't need another charger, the review and features of the MRC Brain charger at Tower Hobbies for $64.95 is pretty inviting...........if only one of my chargers would break down and give me a reason to buy the MRC Brain.......
Paid $19 for it.
#98
NJ
Hi, Tell me something....
I have an Astro 110 charger. I am currently flying 90% parkflyers. I dial in the amps and charge all day long at the field. I fly with my 2 brothers and sometimes we get a bottleneck at the charger causing someone to have to wait.
If i purchase the Sirius charger you are talking about, how will my charging change or get better. Also, can you charge while your driving with any peak charger??? And can I charge more than one pack at a time with the sirius???
Thanks for your help........I will wait for your response before I buy!!!!
#99
My opinion
The sirius charger ain't no different then the Ace Smart Charger Pro series http://www.acehobby.com/products/ele...rge/index.html
Only difference I see is the price however I plan on purchasing the Dymond Super Turbo Charger here real soon. I understand it does the same thing as the super nova maybe more at a lower price.
http://www.rc-dymond.com/Chargers/20156SuperSmart.htm
Blackie
Blackie
