How to Questions.
FL
Hi all, I wouldlike to ask if there is a web page or even literature on how to construct baterry packs? I would like to learn how to contruct my own batteries, I will be using them on Helis, Planes and R/C Cars as well. Any information that you may be able to provide will be greatly appreciated.
P.S. I would also like to ask where to purchase all that I would need to construct the battery packs.
Seaknight
Seaknight
![](/forum/images/badges/premium_member.png)
http://members.aol.com/davthacker/cellsoldering.htm
Personally I'd rather buy quality asssembled packs from
http://radicalrc.secure-mall.com/sho...17&cart=338716
or NBS batteries
http://www.hangtimes.com/nobsbatteries.html
Unless you can solder well you run the risk of melting the seal from overheating the battery. Learn to solder on dead cells. The key to soldering well is a clean well tinned soldering tip on a good iron. My 60 watt Weller is temperature controlled and sold for $125 15 years ago. Everyone goes on and on about cleaning the batterys and the braid or brass strips, using 60/40 rosin core solder but unless the iron tip is tinned with solder to transfer the heat efficiently you'll put too much heat into the joint and ruin the battery. 5 seconds max per joint.
John
or NBS batteries
John
Opps, forgot RCU University Course on soldering
http://www.rcuniverse.com/magazine/a...article_id=172
Last one
http://www.traxxas.com/support/howto...build7cell.htm
John
Last one
John
