Triton power supply question, how many amps?
I just bought a Triton and want to use a dc power supply at home. The manual states that a supply with at least a 13amp output should be used. If the charger has a maximum output of 5amps why would I need a power supply with such a high output? Anyone using a power supply they bought with lower rating than this? I've searched the posts but haven't found this answer yet. Your help is appreciated.
RE: Triton power supply question, how many amps?
Compare current in wattage. Voltage times current = watts. The Triton uses a switching power supply so it can deliver more than 12 volts to the batteries being charged. I think you will find it pretty close to the recommended supply. So 12 volts * 13 amps = 156 watts. Max voltage to batteries 24 cell NiCd = 28.8 volts @ 5 amp = 144 watts
John
John
My Feedback: (325)
figure the watts output by the battery voltage and current being charged. As long as the voltage of the ps is between 10.5-15 then use a ps with slightly higher wattage than required.
Many of us are using a tiny 3 amp ps for doing small batts like radio batts and is plenty of power.
ps Triton is a 90 watt max charger, I have maxxed it out many times with a 100 watt ps.
My Feedback: (325)
Yep, that is usually one of my first questions as I tend to use chargers to their potential.
It is actually in the manuel if you want to do the math. (kinda)
What do you mean when you say 90 watts max? Is that the max it will put out?? Thanks LeeU
ORIGINAL: U-dUd
My Feedback: (10)
My old reliable (and green stickered )triton overheated two packs today. The first was an 1800 ma 6V NiCad pack, and the other was a 650 ma 4.8 V NiCad pack. I replaced my home made charge lead this evening with one that was made by MPI or someplace like that, but no reason to suspect it was bad. So far, no problems with the new charge lead, but I have a question;
I've been using a radio shack 10 amp power supply for the triton. When the overheating problem happened, I had the triton as well as an ace super smart charger hooked up to the power supply. Is it possible that both chargers pulled too much on the power supply, and it (the power supply) somehow tricked the triton into overcharging the packs? The 650 ma pack suffered melted heatshrink and got pretty well cooked. I'm sure the settings were correct, and both packs overcharged while the triton was set to charge at 0.4
I didn't have a temp sensor hooked up, but NOW I do
Any suggestions are appreciated.
JW
JW
AZ
Prop Striker, wouldn't the formulas listed make your power supply capable of 29 amps? The reason I ask is im looking to purchase a 150 watt computer ps. -danny
ORIGINAL: PropStriker
I use an old Computer Power supply...Its 350 watts, 7A max. It handles my 2100 Lipos with ease.
My Feedback: (325)
ORIGINAL: John Wells
JW
JW
CA
As a pragmatic reply, I use computer power supplies of 8 and 10 amps to power my Tritons. Have charged a couple of Lipos at 1.1 amps using two Triton's at the same time on one power supply many times with no problems. I have not tried to charge anything bigger yet.
NV
I have an old 250 w, I think it pushes 7 amp. AT power supply from some old computer and would like to know how to hook it it to use as a power supply for my new Triton. would this be enought to charge a nicd 2000 mah at 2 amps??? I think this would be the biggest battery I would be charging, untill I go lipo for my RC18.
CA
I'm guessing that you should be OK.
Here is the link [link=http://www.rcbatteryclinic.com/]Red's Battery Clinic[/link]
On the left hand side go to the bottom and click on the link to PC Power Supplies.
CA
i know this is an old post but i was wondering if http://www.radioshack.com/product/in...ductId=2103960 this would work please reply.
The Triton, or any other charger, could care less where it's power comes from as long as the voltage and current is sufficient. Allow for about 20% (it is usually less than 20%) overhead or inefficiency so, if the current you are charging at multiplied by the voltage of your battery when fully charged times 1.2 is less than the supply voltage multiplied by the current being drawn while charging, your power supply is sufficient.
