Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
Peak detection sensitivity
Old 03-27-2006 | 11:38 PM
Default Peak detection sensitivity
On my charger, I can adjust the peak detection sensitivity between 3mv and 15mv. Default is 8mv. For those in the know, what happens if I move the sensitivity detection closer to 3mv or closer to 15mv.
Thanks.
Old 03-28-2006 | 03:16 AM
My Feedback: (325)
Default RE: Peak detection sensitivity
moving closer to 3 mv will terminate charge slightly earlier. 15 will go slightly longer.
Old 03-28-2006 | 08:11 AM
gerwen's Avatar
Depending on what types of batts and your charging rate, setting the sensitivity too high (15) could make it so that the charger will never sense a peak, and can overcharge and damage your batts.
For Nimh i use a peak of 5mV. I don't have any Nicads, but i think 8-10 is a good range for them. (Someone correct me if i'm wrong.)
